C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Dyno numbers
Old Jul 18, 2025 | 07:30 PM
Williams3803's Avatar
Williams3803
2025 C7 of the Year Finalist - Modified
Default Dyno numbers
Performance shop just called and told me the dyno tune was a little over 1,000whp on E50. How mich more should I gain on full E85?
Old Jul 21, 2025 | 05:20 PM
2kHPC6Z's Avatar
2kHPC6Z
Very little if any
Old Jul 26, 2025 | 03:26 PM
helga203's Avatar
helga203
what boost you running??
Old Jul 30, 2025 | 03:16 PM
Williams3803
i believe 20 on an Procharger F1X
Old Aug 4, 2025 | 10:15 AM
ZO6LIFE's Avatar
ZO6LIFE
Originally Posted by 2kHPC6Z
Very little if any
This right here. Once you hit the 50% ethanol levels the maximum gain is just about there. You will gain more with a higher E level but it hardly outweighs the effort to find it. Unless you are tracking......
Old Aug 4, 2025 | 11:48 AM
Williams3803
Gotcha, the pump E85 closest to me is about E70 to be honest. I didn't want to search for a higher level if it wasn't really worth it. It seems like for fun sake, E70 should be fine.
Old Aug 17, 2025 | 04:14 PM
thehulk's Avatar
thehulk
Any particular reason you elected to go the F1X route for 1,000rwhp? There are a few more efficient blowers for that level that can out perform the F1X
Old Aug 17, 2025 | 11:37 PM
Williams3803
Honestly, the shop said I should go with the F1X. I think the F1a-94 would have been a better option. I have the fueling for 1500 hp + but not really sure if they built the motor to handle that much boost. This is my first built car and I am trying to learn as I go. I do feel that the F1x comes on later in the RPM which means I don't have to feather it as much. Plus I don't have a built trans or diff right now. I may end up buying a F1a94 blower and switch it over to see the difference in the power and torque bands. This isn't a dedicated race car so I don't want to only be able to run slicks to even get on it.
Old Aug 19, 2025 | 09:42 AM
Tristen1963's Avatar
Tristen1963
didn't Cordes Performance explain to you not to do the F1x?
Old Aug 26, 2025 | 10:36 AM
Williams3803
By the time I had that input the shop had already ordered and received the F1x kit. I just went ahead and let them finish the install. Maybe I should have stopped them and made them switch it out but I didn't. I will probably just end up buying a F1a-94 head unit and switching and getting it re-tuned to see the difference.
Old Aug 26, 2025 | 11:07 AM
Tristen1963
Been there done the exact.
Old Aug 26, 2025 | 11:22 AM
Williams3803
What was your impression of the different blowers? Did you like the F1a-94 better or the F1X?
Old Sep 1, 2025 | 08:43 PM
9sec's Avatar
9sec
ignite ethanol fuels will give you the best gains. for me local my tuner carries it from e95 to e115 red. fantastic consistent fuel
Old Oct 3, 2025 | 05:01 PM
thehulk's Avatar
thehulk
If you wanna trade your F1X for my F1A94
LMK
Old Oct 8, 2025 | 11:42 AM
helga203's Avatar
helga203
I don't understand why change the x, it is a better blower. You easy have 200hp more left in that blower. Im running 28lbs. By 3k ish im at 6lbs tons of TQ way more then my tires could handle. I do not like losing so the hp is there when i need with confident i will win and i have.
I ve raced many 1000hp car and they had no chance. By the way first gear can only handle half throttle. The temp must be at least min 80* out with the streets heated during the day with sun.
To Dyno numbers
