C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Porting stock intake
Old Feb 2, 2026 | 08:27 PM
dcw70's Avatar
dcw70
Default Porting stock intake
I'm thinking of having my stock lt1 intake manifold ported. The question that I have is, will opening up the snout (flange where the throttle body mounts) for a 95mm throttle body weaken it too much for boost? I currently run a solar ported throttle body. I'm at 9.3lbs of boost with a p1x. Thanks in advance!
Old Feb 3, 2026 | 10:53 PM
Dcasole's Avatar
Dcasole
I am running an EdgyVette ported manifold with a procharger . I'm not sure if its opened up to a 95 MM , I posted a picture below . @Cajun @ Edgyvette is a member here , you can also contact him thru the Edgyvette website
Dave
Old Feb 3, 2026 | 11:07 PM
dcw70's Avatar
dcw70
Wow, that looks amazing! Sent mine off to GPI today. Hopefully it comes back looking like that!!!
Old Feb 5, 2026 | 01:37 PM
^&right's Avatar
^&right
I also bought an EdgyVette ported intake. ~$350. Money very well spent.
Measured it against the stock intake and saw around .030-.040 difference at the inlet. Dyno'd back to back I saw ~15hp increase in the midrange and maybe 2hp up top. More than anything, it increased my redline by 750/800RPM. I am also running an A&A supercharger.
I have 600rwhp/545tq with an M7
Old Mar 22, 2026 | 06:15 PM
dcw70's Avatar
dcw70
Default Ported Intake
Well, just got my stock intake back from GPI and re-installed. Temperature is not the same as last fall, but now I'm at 7.2 lbs of boost. I was looking to lower boost, has anyone had simular results? I didn't record atmospheric pressure, temp, blah, blah, just looking to see if stock lt1 intake porting usually results in 1.5 ro 2 lbs of boost loss - generally. Thanks!
Old Mar 22, 2026 | 07:13 PM
Dcasole's Avatar
Dcasole
Well, just got my stock intake back from GPI and re-installed. Temperature is not the same as last fall, but now I'm at 7.2 lbs of boost. I was looking to lower boost, has anyone had similar results? I didn't record atmospheric pressure, temp, blah, blah, just looking to see if stock lt1 intake porting usually results in 1.5 ro 2 lbs of boost loss - generally. Thanks!
Boost is a byproduct of restriction, reduce restriction reduces boost but increases power (in most cases) ....
Make sure you check your belt as they stretch ....
After really tightening my belt as I was battling some belt slip and was only getting 5 to 5.5 pounds of boost, as you know I have a ported intake, ported throttle body, 1 7/8 headers into high flow cats and a 3-inch mid-pipe and a stock 4.5-inch Procharger pully below are my numbers
It was 75 degrees and sunny today here in ATL low DA, perfect boost weather .... I may or may not have made a run today on the "Streets of Mexico" my boost gauge records max boost which today it was 7.2 Pounds .. I was on my brand-new Michelin PS4's street tires not my drag radials and had TC on and even putting some heat into them it still was a bit of a pedal fest as it was fighting for traction all the way thru the top of 2nd gear
I am really fighting the urge to pully down .....
Can't wait for Atlanta Dragway to open this year, even if its 1/8-mile IHRA ....
Dave
Old Mar 22, 2026 | 08:45 PM
dcw70's Avatar
dcw70
Dave
Thanks for the input. Weird, my procharger came with 4.25. That had me at 7.6lbs, went to a 4.13, increased boost to 9.3, ported intake and boost went to 7.2. Car sure doesn't feel any slower, thats for sure!
Old Mar 22, 2026 | 09:04 PM
SteveJewels's Avatar
SteveJewels
Dave
That is true of a positive displacement SC. It shovels air into the closed container of the cylinder.
CSCs, Turbos, and Lysholm Screw superchargers compress air which = boost.
Old Mar 22, 2026 | 09:38 PM
Dcasole's Avatar
Dcasole
Check your belt , it has to be tighter that you feel comfortable with
Dave
To Porting stock intake
