??? Which is faster ZL1 or base C7
Location: KADS- If it has wings or an engine, I can break it. Dallas TX
The base C7 as fast as a Z06C6. It would be nice, not very likely. IMO, GM charges a lot of money for the Z06 option. To outperform it with a base model, makes you wonder why they are charging so much extra.
the '01 c5z was 385hp, '04 c5z was "rated" at 405hp though it is actually higher than they claim. The base '05 c6 is 400hp and .4 seconds slower from 0-60.
One could say, if history is any indication (or the simple fact that the competition has raised the bar) a 500+hp (0-60 in 3.9) base c7 is likely.
Just my thoughts.
From what I understand, which is very little,
Just my thoughts.
Just my thoughts.
The LS7 and aluminium chassis make the Z06 so much more expensive (low volume production).
The C7 will raise the performance bar for everyone... once again.
My projection:
Initial intro of the C7 will have the same power train including engine as the base C6 ... so performance improvements will be via a reduction in weight (if anything significant)...... GM's effort on the C7 is on the interior and info-systems .. with limited effort to "re-skin" the body on an all aluminum frame to be used on all C7's.
Significant gains/improvement will be in year 2 and 3 of the C7 improved engines, transmissions, etc.... and when they will bring in more carbon fiber, wide bodies for the ultra performance versions, etc.
It might still be a 6.2L LSx based V8 but there will enough significant changes/power increases made to it to give it's own designation/name I bet.
Your other projections/ideas seem like possibilities though.
I'm confident that GM can do better. Maybe not 550hp, but the base model doesn't need that much yet, and what power they do add can likely be done for less cost, size, and weight than that supercharger.
Won't fit under the hood. It also adds a chunk of mass to the car, and pushes the weight distribution forward.
Additionally, someone mentioned carrying over the same drivetrain as the C6 Coupe. That is a nonstarter. Doing that will kill loyalty sales, and most early adopters.
I think the primary goal is to put something out there that every C6/C6Z owner would want to trade up to. It really wouldn't take much after you satisfy those who care so much about the interior. A base C7 that looks better than a C6Z that is equal to or greater than the performance of a C6Z would pull in a new customer base while keeping the old.
No I believe it will be a new DI 6.2L engine (501.4 HP ). I was just pointing out how easy it would be to get to over 500 reliable horsepower by simply using an existing engine (but what hood are you talking about? and why not push the engine back a little further since it's a newly designed vehicle and chassis?... just brainstorming here).
.Jinx
Though it likely won't even 'need' 500hp to beat a Camaro ZL1 anyway.
So far, even a stock base C6 LS3 can beat a stock ZL1 in a straight line (but likely not around most road courses).
Now, the Camaro ZL1 is destined to put in quicker 1/4 mile times once cooler weather hits but thus far it's:
Corvette C6 LS3 = best of 11.71@119.94mph
Camaro ZL1 LSA = best of 11.93@116/117mph
So in short, yes, the base Corvette C7 should also be faster than the current Camaro ZL1.
#33
There is some confusion surrounding that and I really wish both GM and those that wrote these articles were more clear on the subject.
The 11.9 passes (achieved with both the manual and automatic test cars) were done on the bone stock factory OEM tires. And the weather conditions that day were not favorable to great 1/4 mile times either. I don't think they cut solid/consistent 1.6s, I believe it was a high 1.69 and some 1.7s which can (and has) been done on stock tires in other cars with less power.
Now this is where the confusion/misunderstanding comes in, they were also testing drag radials on both cars that day (both 18" and 20" sizes) and did go even quicker on them, but those 11.9s were achieved in bone stock trim:
http://www.motorauthority.com/news/1...-the-11s-video
A manual transmission ZL1 turned in a best run of 11.965 seconds at 117 mph, while the (theoretically faster) automatic ZL1 delivered a time of 11.936 seconds at 116 mph.
Both cars ran on the stock Goodyear Eagle F1 Supercar G-2 tires, not on drag radials. In fact, Chevy is quick to point out that using drag radials may produce a time of under 11.49 seconds, which would require the addition of a five-point roll bar to run on NHRA-sanctioned tracks.
Another thing...there's no such thing as a "hero run". Either the car can run the number or it can't. Doesn't matter what "most" run because that could be the driver's fault, not the cars.
If someone runs an 11.9 and on the very next pass they get excessive wheel spin and the car suddenly runs a 13.5 that doesn't automatically make it a 13 second car...it still ran the 11.9 and that is what the car was capable of with that driver in those track/air conditions.
Bone stock (yes, right down to the tires) Camaro ZL1s will be hitting 11.7s (or quicker?) at over 120mph in the 1/4 mile before the year is over, you can almost quote me on that.
#34
If you look at the 2 time slips in the vid, the 11.9 passes has a 1.6 60'. They were on a tire. The best times I've seen from a stock ZL1 is mid-low 12's. Yes the base C7 will destroy a ZL1.
#35
We are talking Z06 territory now.
A zl1 barely beats a c5z and we are talking about 10 year old technology. It can't beat a ls3 car so what makes anyone think it will be faster then a C7?
#37
But I have to give the Camaro ZL1 the credit that it's due and it DID in fact run an 11.9 on bone stock factory tires regardless of it's sixty foots.
I'm sure there were some 1.6s accomplished on the drag radials that day as well but again, the one (just one) 11.9 time slip in the videos shows a 1.698 not a 1.600 (big difference there, and I do agree that a 1.60 is not probable for a car of that power/weight to achieve on stock tires but a high 1.69 and a 1.73 (as the other 11.9 time slip reads), though not easy or common, is possible with a great manual driver).
It's all right here in black and white (and red ):
http://www.autoblog.com/2012/05/04/2...11-93-seconds/
*UPDATE: We've placed a call to Chevrolet inquiring whether these times were recorded on stock tires, as the press release indicates, or on drag radials. We'll add another update as soon as we hear back.
*UPDATE TWO: The times quoted in the press release – 11.93 for the auto and 11.96 for the manual – were recorded on the stock Goodyear Eagle F1 Supercar G:2 tires. According to Chevrolet, the team knocked about a tenth of a second off those numbers with the Mickey Thompson drag tires.
#38
The car has 580hp, launch control, the tires are 305mm wide and aren't exactly the ultra hard rubber compound of a 1997 C5's runflat either LOL.
Again it is rare but there are even a few stock Corvettes that have cut high 1.6 sixty foots on stock Goodyear run flats as well, 1.7s are more common though.
The 1.698 (again, that's practically a 1.7) sixty foot and 11.96 pass was from the manual car, not the automatic car (which ran an 11.93 on the aforementioned 1.73 sixty foot).
As you well know, a manual transmission with a clutch allows for a sort of 'infinitely variable' stall speed, one can leave at almost any RPM that they choose (within reason) in order to maximize their launch. This was done a prepped drag strip as well don't forget.
You may not be "buying it" but that is what they're claiming emphatically and as one who has done A LOT of drag racing/test passes with stock/bolt ons only cars on all different kinds of tires/track surfaces, I do believe what that their claims are very possible/probable too.
#40
Just doing my part in educating folks.
