Transmission speculation
Tried and true tremec trans or should GM explore other options?
What about a DCT trans or even better the new transmission in the 370z. ( manual with a clutch pedal but performs rev matching while downshifting)
The latter would be a very nice touch I think.
The Consigliere
Received 5,447 Likes
Expect a much improved torque converter/paddle shift auto.
And a stick shift.
And a stick shift.
Regarding the M6, I predict it will still be the Mexican-built 6-speed. More gears may come after 2-3 years for both boxes.
How do ya figure?
Viper = 6 speed manual only
Corvette = 6 (or 7?) speed manual with an automatic as optional
Z06s and ZR1s = also manual only
The way I see it, the Viper must not be trying to compete with the Corvette.
I could be wrong, but I believe that Chevrolet already confirmed a 7 speed manual, and that there would not be a DCT option initially.
GM has work to do! A hot transmission would make them able to use a lesser powered souped-up Z06 against the Viper, and maybe save some gas!
Note prior C7 thread on this same subject with 207 posts as of 4/30/12:
http://forums.corvetteforum.com/c7-g...nsmission.html
Received 4,377 Likes
Received 8,929 Likes
They will really miss the performance ball if they don't offer a 7 speed DCT like the others do. It is the price of playing in the big leagues.
Maybe drop the automatic and offer a manual transmission as standard with an optional DCT that satisfies the people who want/need an automatic and the people who want all out performance. Then after a year or so when the old die hards see how much fun they are missing drop the manual and offer the DCT as the only transmission. On a low volume car a single transmission choice probably can save a lot of money although the cost of the individual transmissions may be more. Transmission logistics support would be cut in half and overall it just might have a bottom line impact on a low volume car's cost.
Bill
Bill
Former Vendor
Bill
Bill
DCT is a great option for the auto crowd, but it wouldn't be my cup of tea.
I would prefer a traditional manual over the absolute fastest acceleration. For me, just because I could program a car to run the fastest lap around a track on autopilot doesn't mean I would want it to.
Instead of the stick pushing some levers inside the transmission the paddles send electrical signals to some solenoids in the transmission that push the levers instead. Same operation just a different way to make it happen. No different than fly by wire throttle control Vs cable or rod throttle control or hydraulic assisted steering Vs electrically assisted steering.
Bill
Former Vendor
It is also a great option for the manual crowd. It is just a manual transmission that can be operated in manual or automated mode. No autopilot to it just damned quick shifts. In manual mode the only differences in operation are you don't have a clutch pedal as the transmission operates the clutch for you while you use paddles on the steering wheel to change gears instead of a stick protruding from the floor. Don't get hung up on flopping a stick around to shift gears.
Bill
Bill
But a missed shift under hard acceleration can be irritating, and embarrassing, if not expensive and noisy.
