GM released information in their restructuring plans that indicated HCCI was about to surface, projected for 2015. The sensor bungs in the manifolds may be the biggest indicator that HCCI may make its debut on the Gen V. The autoignition process of HCCI is highly temperature dependent and the monitoring of the combustion health of individual cylinders may be necessary.
Up to now, HCCI has always been shown by GM on small displacement motors and good at low rpms only. That doesn't mean it hasn't been developed further! It is one of at least four technologies under study by GM R & D.
SI (spark ignition) - in production
WG-SIDI (Wall-Guided Spark-Ignition Direct-Injection) - in production
SG-SIDI (Spray-Guided Spark-Ignition Direct-Injection) - near production
HCCI (Homogeneous-Charge Compression-Ignition) - still in resaerch
So, IMO, WG and/or SG, SIDI is more likely to show up on Gen V engines initially instead of HCCI.
It is true that HCCI is still in research, there are significant problems for the stability of HCCI to be run over all operating ranges. Though, I do not think it's an irrelevant lab project either, for GM has already demonstrated a functional HCCI vehicle years ago (08 or 09?). The advantage of HCCI over the technologies listed, is that it does not require stoichiometric ratios so the amount of fuel injected then becomes a function of how much power is desired. The maximum power yield is strictly limited though because of the 50-90% EGR that's required to add enough heat to auto ignite the charge. That disadvantage goes away when you're talking about a dual phase motor, it even becomes an advantage that will yield efficiency for cruise conditions. Unthrottled and without pumping losses, much of efficiency gap is bridged for large displacement engines. Not to mention HCCI is more thermodynamically efficient. IMO HCCI's looking pretty suspect for the new combustion technology Gen V's been claimed to feature.
One of the easiest ways to control heat on the fly, and so extend the operating range, would be with dynamic compression. I would guess a combination of VVL/VVT.
Direct injected VVT 6.2 sounds right. And with 480hp, that would be more than enough power to send the new C7 to 60 in under 4 seconds!
And if the car weighs 150 pounds less then the C6, then that is the equivalent of an additional 15 HP.
But, the C7 dosen't need 480 HP to get to 60 under 4 seconds. The C6 Grand Sport will do 0-60 in 3.95 seconds with 436 HP. Knock of 150 pounds and you are now down to 3.8 seconds 0-60.
"The 2013 Grand Sport Coupe
It will make your heart race, whether you’re on the track or not. The 2013 Grand Sport coupe is the only luxury sports car in its class to boast 0–60 mph under four seconds, 1g cornering capability and an impressive 26 MPG highway† fuel economy for an unmatched combination of performance and efficiency."
