Why LT ?
Old Oct 24, 2012 | 03:44 PM
HZ06's Avatar
HZ06
Default Why LT ?
Why they are going back to the LTs RPO? It could be called LS4, or LSB.
Old Oct 24, 2012 | 03:48 PM
RC000E's Avatar
RC000E
All about the marketable hype man. Why build a throwback camaro vs moving forward? Why do all this throwback bs. Just trying to create an attachment to the older guys to make them buy new ones. Same with the ZL1 comeback, ZR1, LT1...you name it....
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
i was wondering the same
Really dont care for the LT- Desigination again
Old Oct 24, 2012 | 03:49 PM
nullpointer's Avatar
nullpointer
LS4 already exists
- snip from wikipedia -
"The LS4 is a 5,328 cc (5.328 L; 325.1 cu in) version of the Generation IV block. Though it has the same displacement as the Vortec 5300 LY5, it features an aluminum block instead of iron, and it uses the same cylinder head as the Generation III LS6 engine. The bellhousing bolt pattern differs from the rear-wheel drive blocks.
This engine is adapted for transverse front-wheel drive applications. According to GM, "The crankshaft is shortened 13 mm – 3 mm at the flywheel end and 10 mm at the accessory drive end – to reduce the length of the engine compared to the 6.0L. All accessories are driven by a single serpentine belt to save space. The water pump is mounted remotely with an elongated pump manifold that connects it to the coolant passages. Revised oil pan baffles, or windage trays, are incorporated into the LS4 to ensure that the oil sump stays loaded during high-g cornering."[6] Active Fuel Management is also used. Output of this version is 303 hp (226 kW)/300 hp on LaCrosse Super and 323 lb·ft (438 N·m)."
flange's Avatar
flange
St. Jude Donor '14
they wanted to builds goats and judges, but couldnt bring themselves to reopen the pontiac name.
Old Oct 24, 2012 | 03:52 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
I agree. It's going to be so confusing. It shouldn't be LS# because this is a new gen. It should be L_1. Anything that hasn't been used before. I'd be happy with LX1.
__________________
Contact:
(e) zach@katechengines.com
Old Oct 24, 2012 | 03:54 PM
mike100's Avatar
mike100
how to differentiate this engine series?
Gen5LT1?
LT1_G5?
its gonna be a mouthful either way.
Old Oct 24, 2012 | 03:58 PM
Tech's Avatar
Tech
This is the only thing I don't like about the C7 thus far.
Old Oct 24, 2012 | 04:00 PM
BeaZt's Avatar
BeaZt
St. Jude Donor '14
Can't wait to see what you guys at Katech come up with.
Old Oct 24, 2012 | 04:17 PM
b4i4getit's Avatar
b4i4getit
The LT designation was used to denote Light Truck. Not sure why they are going back to that.
Old Oct 24, 2012 | 04:20 PM
torquetube's Avatar
torquetube
Yes. I think GM overestimates how nostalgic people are about these engine RPOs.
I also think GM underestimates how much the few people who _are_ nostalgic for old RPOs are annoyed by having them re-used.
Old Oct 24, 2012 | 04:24 PM
wildanblue's Avatar
wildanblue
Not that it matters... but a 1970s LT1 was a world apart from the 1995 LT1 yet there is little confusion as to which is which.
Old Oct 24, 2012 | 04:28 PM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
I hate the engine designation. LT1 is attached to a garbage optispark motor that wasn't worth a crap.
I think it should have been named LR1 since LS_ is gen IV and LT1 has already been done. It's the next closest letter in the alphabet that rolls off the tongue.
Old Oct 24, 2012 | 04:32 PM
Zap City's Avatar
Zap City
St. Jude Donor '13
Another vote for a sh!tty motor designation. Come on General. LX1 sounds pretty damn cool in my book.
Old Oct 24, 2012 | 04:35 PM
HZ06's Avatar
HZ06
With LR1
Old Oct 24, 2012 | 05:01 PM
c54u's Avatar
c54u
Seriously, it's only a freakin' name for the engine!!!! Way too many concerned about names, or how little horsepower the engine has or whatever (other thread posts). It's about the complete package and experience of the car once it comes out and you get to see it and drive it. Every generation is better than the previous one and this generation will follow suit.
I am just waiting for Jan 13, 2013 to see the real deal.
Old Oct 24, 2012 | 05:08 PM
5knives's Avatar
5knives
But....I also agree with them. I think rehashing the LT1 moniker was dumb. A new gen motor designation is more than appropriate for the new gen Corvette.
To Why LT ?
Old Oct 24, 2012 | 05:15 PM
bladex10's Avatar
bladex10
I HATE the LT1 name. They shouldve gone with something new. Hell LT2 or something wouldve been better.
Old Oct 24, 2012 | 05:19 PM
OnPoint's Avatar
OnPoint
The Consigliere
The C3 LT-1 was a honey of an engine, and birthed the first ZR-1.
Old Oct 24, 2012 | 05:29 PM
CPhelps's Avatar
CPhelps
GM has a limited number of RPO codes they use. It will have been 18 years since the LT1 was last used, nearly as large a gap as last time. LS4 would have been much more confusing, since the LS4 was used as recently as 2009.
It makes sense to drop the LS_ since it is a new gen, although they didn't between Gen III and GenIV, possibly because of how similar those engines were to each other.
I think context clues should be enough and it wont be that bad.
