In less than 30 months (9/2005-12/2007), three GM engineers authored at least 42 patents on eight-speed automatic transmissions. Go to Google Patent Search
"general motors" (Usoro or Bucknor or Raghavan) "eight-forward" "seven torque-transmitting"
To my eyes, the most recent is 7303501. As I look over an enormous variety, I see ratio spreads of above 8 to 14. The 6L80E is near 6. When there are this many gears, the rear-end ratio becomes a non-issue.
The rub here is that the eight-speed automatic may not be ready in time for the 2014 C7.
So? There are lots of possibilities with such a tranny for the C7 generation. The fact that it isn't in the first year doesn't mean much.
the A4 was carried over to the 2005 C6. The 2005 run was then extended several months because the A6 was not ready for prime time for the 2006's until around Sept/Oct instead of the normal June model year changeover.
GM seems to have a new group of people furiously producing patents on automatic transmissions. Try entering this string into Google patents;
"general motors" transmission "nine-forward" (Phillips or Hart or Carey or Wittkopp)
In spite of the word "nine" in the search, many eight-speed patents show up. I suspect these are more representative of GM's new eight-speed AT family.
Interestingly, there are 24 patents on ten-speed automatics by these same guys.
I don't know why they would want an 8 speed, GM couldn't even program the 6 speed automatic so it was driveable.
They'll probably program it so it shifts into 8th gear at 15mph to save gas mileage, and then you'll have to push the pedal all the way to the floor to make it downshift, at which time it will do a 6 gear downshift and rip the rear end right out from under it, after a considerable delay imposed by the torque controls.
The actual transmission design will be a moot point, because they will slaughter it by the way they program it. It wouldn't matter if it was a 20 speed transmission, it still won't provide any torque or acceleration when it shifts into it's highest gear at under 20mph.
So not only myself but every other A6 owner out there needs to wipe that silly grin off our face when in our Vette. I accidentally have put 17,000 miles on my undriveable car in 14 months!
I tend to think of these 8-10 speed auto trannys like a number of electric/hybrid cars with single speed/CVT trannys. It may well feel like a continuously variable transmission with just a TON of torque that you never actively shift but that responds to your right foot.
Hence, the CHANGE!!
You might want to ask yourself why so many A6 owners get their transmissions "tuned" so that the car will actually downshift when they step on the gas. Try doing some mild accelerations at 45mph next time you drive your car and see what happens. See how far you have to push on the gas pedal at 45mph before it downshifts, and then maybe you'll understand the problem, and if you push it far enough, you'll get to experience the infamous 4 gear downshift all the way to 2nd gear. If that isn't a driveability issue, I don't know what is.
This very forum is filled with threads about the problems in the programing of the A6. Entire businesses have arisen just to reprogram this transmission.
The GM automatic presently shifts from 1st to 2nd in 230 milliseconds and 2nd to 3 rd in 200 milliseconds. I drive manual transmission vetted and the programing impresses mec7 automatic will rock!
So the C7 in this regard is going to continue to be in a disadvantage against those cars.
Well, maybe certain areas (transmission alone) of the Corvette will be at a disadvantage against those cars, but certainly every facet of the entire car itself won't be.
Price/cost of ownership/ease of maintenance, fuel economy, styling (subjective), interior space/comfort, availability etc are all potential areas where the Corvette might actually have plenty of advantages over other sports/performance cars.
Its not the time it takes to change gears that is the problem. It is the speeds and throttle angles at which it's programed to shift gears, as well as the torque control limits. If they don't address the programing downfalls, it will have the same crappy shift speeds programmed into it that the A6 does.
Geez. Put it in S mode and shift it the way you want if you want to have fun.
All you gotta due is quickly roll into the gas pedal UNLESS you want to use the paddles aggressively. Either way, it will shift quicker than 99.9% of all Corvette manual drivers.
Faster than DCT Sequential atuomatoc or completley manual Shifting
A6 is now a Faster shifting transmission than DCT Transmission.
Sequential Manual Mode (user must downshift or start off in sixth gear or last gear used will not shift or downshift unless paddles ar used)
Automatic sport mode
(Fastest acceleration with .125 second shifts)(Faster than a DCT)
or user may select only manual Shifting
This is the current A6 in my 2012 GS .
A8 will without a doubt use the same spec's.
Note: A6 is Rated for 650 HP
A8 most likely will be rated for 750 HP.
