C7 high performance variants
Old Dec 17, 2012 | 09:59 AM
bigterpsfan's Avatar
bigterpsfan
Default C7 high performance variants
Assuming there will be a high performance version of the C7 down the road, do you think they will offer it as a convertible? I know rigidity is key, but other manufacturers seem to have pulled it off. If so, given the extra weight is a hard top convertible feasible?
Old Dec 17, 2012 | 10:04 AM
Rocketmanwpb's Avatar
Rocketmanwpb
Since the C5 the Vette has been designed as a convertible from the start. Generally GM has brought the vert out shortly after bringing out the coupe. Same as with the higher performance versions. The higher performance versions will appear down the road to keep interest up in the line.
