Only 99lbs lighter
Old 01-13-2013, 07:48 PM
  #41
gonefishn
gonefishn's Avatar
St. Jude Donor '09
But 57% stiffer plus 90-ish pounds makes a difference.
To be honest though it is hard to image 57% stiffer than the C6. Maybe than the convertable ?? There is almost no flex in the Z06 C6.
  #42
flashburn
flashburn's Avatar
Originally Posted by JLinNY
Why didn't they just say frame? You don't have to repeat anything, I just watched the video again.
They did say frame. In fact, they showed it in big bold letters, "FRAME". There is no argument here, you can STFU already.
Old 01-13-2013, 07:49 PM
  #43
TriplBlk
TriplBlk's Avatar
Lots of people are gonna be disappointed.
Are you serious? ........
the frame is 99lbs lighter
The body panels are an ADDITIONAL 37lbs, and the LT1 is 40 lbs lighter...
Sooo yea, little bit lighter ey?
" New aluminum frame structure is 57-percent stiffer and 99 pounds (45 kg) lighter than the current steel frame"
"Innovative use of composite materials, including carbon fiber the hood and roof panels, lightweight Sheet Molded Compound for the fenders, doors and rear quarter panels, and carbon-nano composite for the underbody panels help reduce the weight of the body by a 37 pounds (17 kg)"
  #44
BLKTA
BLKTA's Avatar
Don't forget this..
While the Corvette Stingray retains the racing-proven short/long-arm suspension design, front and rear, the components are all-new. Improvements to the suspension include hollow lower control arms which save approximately nine pounds (4 kg) per vehicle and new aluminum rear toe links which save 2.4 pounds (1.1 kg) over previous steel links.
Every little bit adds up AND they haven't released the actual weight.
I also like this..
An available dual-mode active exhaust system offers a 27-percent improvement in airflow. It features two additional valves that open to a lower-restriction path through the mufflers. When open, these valves increase engine performance and produce a more powerful exhaust note.
Old 01-13-2013, 07:52 PM
  #45
c54u
c54u's Avatar
Originally Posted by VETTEMANN
Not great.
But to be fair, it says the body materials also reduce by another 37lbs.
But 99lbs + 37lbs = 136lbs ~ not the huge savings that some were hoping for.
136 plus
9 plus
2
= 147
plus my food diet of 30 lbs
=187 lbs lighter
Old 01-13-2013, 07:54 PM
  #46
JeffInDFW
JeffInDFW's Avatar
It is actually a little fuzzy. Here, it COULD mean "ALUMINUM FRAME", as a way to make the car stiffer and lighter. So, is the Aluminum Frame 99 pounds lighter by itself, or does the aluminum frame contribute to making the CAR 99 pounds lighter. I took it that the FRAME was 99 pounds lighter, but I see the confusion.
Screen Capture Photo directly from the reveal:
/Chevrolet?v=zsQGcD0TJvw&t=32m8s
Old 01-13-2013, 07:56 PM
  #47
flashburn
flashburn's Avatar
Where did you read that the engine is 40 pounds lighter? I thought it was supposed to be heavier?
That'd be awesome. I'm sure some things will weigh more due to safety regulations, but I'd guess in the end we're looking at ~150 pounds lighter. That's pretty damn awesome. Plus 50 ft-lb more torque than the LS-7 from 1000-4000RPM, and 450/450 peak (at worst). It won't be a slouch in the performance department.
edit: Whoops, 50 ft-lb more torque compared to the LS-3... still:
More importantly, it generates 50 lb.-ft.
more low-end torque than the previous 6.2L engine, matching the 7.0L LS7 engine from the
2013 Corvette Z06 from 1,000 to 4,000 rpm.
Old 01-13-2013, 07:57 PM
  #48
MKenM
Support Corvetteforum!
MKenM's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
They could make it a lot lighter if they got rid of the creature comforts you want.
Old 01-13-2013, 07:58 PM
  #49
jdhommert
jdhommert's Avatar
Where have they said the lt1 is lighter? I thought it was 14 lbs heavier???
  #50
jdhommert
jdhommert's Avatar
DAMN YOU
Old 01-13-2013, 08:01 PM
  #51
TriplBlk
TriplBlk's Avatar
136 plus
9 plus
2
40 LT1
= 187
=217 lbs lighter
Thank you!!!!!finally someone who gets it
I cannot believe the post I'm seeing, including so much ignorance when the info is handed to you!!!
Old 01-13-2013, 08:03 PM
  #52
TriplBlk
TriplBlk's Avatar
I stand corrected lol
  #53
c54u
c54u's Avatar
LT1 not 40 lbs lighter than current 6.2
http://www.digitaltrends.com/cars/20...-6-2-liter-v8/
Also helping efficiency is a lighter aluminum block. Chevy says the LT1 is 40 pounds lighter than “a competitor’s twin-turbo 4.4-liter, DOHC V8 with similar output,” probably a reference to the engine BMW uses in the 5 Series, M5, and other models
Old 01-13-2013, 08:06 PM
  #54
TriplBlk
TriplBlk's Avatar
That's what I get for only quick referencing it lol I new it was 40 but lighter than something
  #55
c54u
c54u's Avatar
Originally Posted by TriplBlk
Um.... In the motor specs given to us of the LT1?
It's 40lbs lighter and 4 inches shorter
Come on, I haven't even been following this section that much haha
BlueOx, keeks, someone help me out here haha
check my post with link about the 40 lbs.....I changed it
  #56
DRLC5
DRLC5's Avatar
I really liked the looks. I also saw this video. It has Bridgestone tires? I thought they went to Michelin tires?
Old 01-13-2013, 08:08 PM
  #57
Chicago1
Chicago1's Avatar
I'm so lost so how much total did they loose? 136?
To Only 99lbs lighter
Old 01-13-2013, 08:09 PM
  #58
S'vette
S'vette's Avatar
And is the weight savings compared to the base or the GS? Since they compared thee performance/speed to the GS. So atleast a 0 60 in 3.8 secs?
Old 01-13-2013, 08:10 PM
  #59
Topas
Topas's Avatar
According to autoblog, the whole car should be 37 lbs lighter than the previous generation. I don't know where they got the numbers, though.
Old 01-13-2013, 08:11 PM
  #60
jdhommert
jdhommert's Avatar
probably at least 150
137 ONLY in the body and frame...they mentioned other chasis weight loss, dunno if that is included, but they've cut weight in several other areas it seems, already mentioned a couple lbs in links, lighter seats, lighter power train cradles....
The 2013 curb weight is 3208 I think.
You know, they could be pretty damn close to that 3k mark...closer than most people are thinking....
Quick Reply: Only 99lbs lighter
