C7 brakes
Old Jan 13, 2013 | 08:44 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default C7 brakes
Rotor diameter (in / mm):
front: 12.6 / 320 (13.6 / 345 with Z51)
rear: 13.3 / 338
Old Jan 13, 2013 | 08:52 PM
trumper Z06's Avatar
trumper Z06
BREMBO
Hopefully with one piece brake pads.
Old Jan 13, 2013 | 09:02 PM
John Shiels
Originally Posted by trumper Z06
BREMBO
see anything different?
18 views and no comment
Old Jan 13, 2013 | 09:04 PM
Robert R1's Avatar
Robert R1
The Z51 brakes should be awesome.
I hope the Z51 package comes with better, non runflat tires also.
Old Jan 13, 2013 | 09:09 PM
trumper Z06
Z51 performance package looks track ready, I hope.
Not sure what the "electronic limited slip differential" is all about.
I don't think it will have torque vectoring... but this is the first I heard about it.
Need more info on LT1 engine but info will be coming out shortly.
Rev matching will help those who can't heel & toe down shift.
I'm still reviewing/digesting info.
Old Jan 13, 2013 | 09:10 PM
Robert R1's Avatar
Robert R1
I'm skeptical on how well revmatching will work on the manual. Will certainly pay attention to feedback from track tests.
Old Jan 13, 2013 | 09:11 PM
John Shiels
digest the info I posted to see something different
Old Jan 13, 2013 | 09:12 PM
John Shiels
computers will handle it fine.
Old Jan 13, 2013 | 09:13 PM
trumper Z06
Hhmmm... rear rotors are larger than front rotors on std. model ?
Old Jan 13, 2013 | 09:14 PM
Kappa's Avatar
Kappa
If it's anything like the 370Z's, it will be just about flawless. You can turn it off if you want.
Old Jan 13, 2013 | 09:15 PM
Robert R1's Avatar
Robert R1
Great to hear. Certain shoes in backroads don't tend well to heel toe so this is awesome.
trumper Z06
\\Yep. Nissian G35 sport was first model I experienced with rev matching. Goes back a few years now.
JerriVette's Avatar
JerriVette
John,
Whats your opinion of the electronic limited slip differential for track use?
I looked and have not found your insights as a guy who loves road course work in your vette.
Old Jan 13, 2013 | 09:16 PM
John Shiels
yep
Old Jan 13, 2013 | 09:17 PM
John Shiels
Originally Posted by JerriVette
John,
won't know till it's on track I am sure it works better they are not stupid and all this for a great price car will be great. Like to see ARM shifting too.
Old Jan 13, 2013 | 09:46 PM
briannutter1's Avatar
briannutter1
I'm hoping some of the goodies are backwards compatible.
Old Jan 13, 2013 | 09:47 PM
John Shiels
I bet way less than C5-C6
To C7 brakes
Old Jan 13, 2013 | 09:55 PM
trumper Z06
Not much...
maybe c5 Z06 18 inch rims will fit (for track use)... that will be about all.
Old Jan 13, 2013 | 09:58 PM
CPhelps's Avatar
CPhelps
Some more brake info:
Originally Posted by MotorTrend
Behind those wheels are standard Brembo brakes that, while slightly smaller in diameter than before, boast 35 percent more swept area thanks to larger pads that cover more area on the rotor face. Z51 cars get larger front discs (13.6 inches versus 12.6 on the base C7) with 6 percent more swept area than a current Corvette Grand Sport and a lot more bite. Chevrolet says the new Stingray will stop 11 feet shorter than before, putting its 60-0-mph braking comparable with that of the mighty ZR1, which we measured at 94 feet.
Read more: http://www.motortrend.com/roadtests/...#ixzz2Humpa5r5
Ozzy12's Avatar
Ozzy12
