Anyone have any estimates on what a 427 version of this would be capable of in a Z06 type model? Could we get to 605hp naturally aspirated or is that in crack smoking land?
I agree as well. For example the Subaru BRZ has a 2 liter thats direct injected and has varible cam timing as well. The current model has 200 horse power with the new model rumored two have 240. Granted it has four valves per cylinder. This new engine does some serious breathing of its own. So considering that a 6.2 liter could easily make 600 horse power all thing being equal. Even though we no that isn't going to happen. They have plenty to work with in the furture.
Perhaps one of the reasons the LT-1 has not seen a substantial boost in power is the current 6 speed automatic. Since it is a carryover and an all new 8 speed is just around the corner perhaps GM didn't want to invest any money in certifying the 6 speed for a lot of extra torque and at the same time didn't want to have to using 2 somewhat different engines ( 1 4 the manual) While I know you can get an automatic ZL-1 it doesn't have the same torque off the line that the new LT-1 does.
I imagine they estimated the numbers very conservatively for a few reasons:
1) They would look like idiots if they overestimated. Now, if final verification comes back at 460-480, they can all pat eachother on the back and say what an awsome design it is.
2) They know they are leaving power on the table in tuning. It is much better to under tune and have a reliable engine with less power than to put it all in there and have them blow up. It's under warranty ya know.
3) They're probably not completely done tweaking the powertrain yet. In one interview, forget which one, they said they still have some tweaking to do on the exhaust. So, see #1.
4) Leaving something in the tune will indeed make later higher output versions look that much better for the extra money.
JoesC5
close
- Member SinceSep 1999
- LocationSpringfield MO
Liked:1,718 Times in 1,226 Posts
Quote:
Remember, the ZL1 was rated at 550hp, then revised to 580hp when it came out. I believe the same is true for the C7.
Then you should also know that the LSA was estimated at 550 HP for the 2009 Cadillac CTS-V and when SAE certified, it was 554 HP. The LSA used in the Camaro is not the same identical LSA as used in the CTS-V. They revised the air intake and the supercharger, eliminated the power steering pump plus some other changes that increased the horsepower from 554 to 580 from when it was used in the CTS-V. GM did not lowball the LSA at 550 horsepower and then it magically came in at 580 when put in the Camaro. There were physical changes made to the engine that increased the horsepower from 554 to 580.Originally Posted by Latterlon
Marketing could be the reason for a lower rating. It allows for future power increases without huge investments. I, too, see it as a near 500hp engine. I think the tune could possibly be the restraining factor, for whatever reason they might have.Remember, the ZL1 was rated at 550hp, then revised to 580hp when it came out. I believe the same is true for the C7.
Quote:
The new LT1 has: (same displacement)
1. Direct injection (proven tech. for efficiency/power increases)
2. Upgraded forged crank & bearings (hint at higher power rating)
3. oil squirters under pistons (cooling) not to mention the cooling a direct injection setup has on top of the piston (cooling = more aggressive timing ability)
4. Variable Valve Timing (power & efficiency)
5. Electronic steering assist?? (Reduced parasitic loss on output?)
6. Airflow increases mentioned by engineers.. (Runner design, etc)
7. Other efficiency improvements mentioned by engineers. (Block, etc.)
8. Last, but NOT least: AN 11.5:1 COMPRESSION RATIO!!
Wouldn't it be a very unlikely that with all these updates, and what we know about these engines, the gain between engines would be 14 hp and 22 tq? (C6 bi-mode exhaust accounted for as similar to what's expected on all c7s) ???? Similar gains can be realized from intake & exhaust upgrades can they not? Which brings me to speculate that yea, 450/450 is a massive potential understatement.
I'd say you can virtually guarantee a conservative 450 hp 450 tq number at the very lowest minimum... perhaps on 85-87 octane fuels...
Realistic expectations would be well approaching 475 hp in my opinion. (Potentially more?)
Further, upgrade potential will be marvelous with the available fuel, timing, cam, etc. options for this engine.
All said and done, it's nothing more than speculation but educated guesses are worth something right?
Bryan.
I have been thinking the same thing ever since I read the specs. Just take the stock LS3 and raise the compression ratio from 10.7 to 11.5 and you'll be over 450 horsepower.Originally Posted by CrystalRedMetal ZR-1
For comparison, the outgoing present LS3; at 6.2 liters, with a 10.7:1 compression ratio, fitted with a bi mode exhaust option similar to what all c7s will have is rated at 436 hp and 428 lb·ft tqThe new LT1 has: (same displacement)
Bryan.
They must have a REALLY conservative tune on that thing.
I think the reason the official numbers haven't been released yet is because they still want to sell Z06's. I'm sure they have the numbers, they are just being coy with them.
I do think more than 450 will be made, how much I don't know, but they did raise the power up to the base C6 to C5Z level of power when it came out.
ExploreQuote:
But 510-550hp on this engine right now? Not a chance.
GM only added DI & a few minor parts, not a supercharger.
And you can bet GM won't do anything soon unless C7 sales tank. Because GM wants to sell as many C7's as they possibly can on newness alone. So they can more easily recoup the massive amount of money they already spent.
Originally Posted by 85scott
GM will likely rate the LT1 engine at 450hp like they say. And then in 3-4 years, change parts to increase the HP & TQ numbers to somewhere between 475-500 on the base model, like they have done before with the LS2 to LS3 changeover. But 510-550hp on this engine right now? Not a chance.
and I think maybe slightly underrated is more what we will see .. Final numbers might be more in the 460 to 465 range tops .. They need to leave themselves room to grow down the line.. Like they did with the C6 as you mention ., interesting this happened in the C5 run , really only with the C5Z 2001 Ls6 making 385hp ands then in 02 they bumped it to 405 hp68/70Vette
close
- Member SinceJul 2004
- LocationRedondo Beach, California
Liked:793 Times in 530 Posts
Quote:
camry. Now put them behind the wheel of 500. I wouldn't insure them.
Insurance killed the muscle car, it can do this too
I've had the same insurance agency since 1969. I've always had 2 or 3 Corvettes insured with them along with the DD's. I pay $650 a year for full coverage on my C6 08. Also, with 5000 miles max allowance, I pay $350 a year for full coverage on my ZZ4 powered C3 68. Apparently with no collision accidents they consider me to be house broken; i.e I'm not going to sh*t on their floor. I live in metropolitan Los Angeles, and I believe these insurance rates are really cheap.Originally Posted by texvette2
Insurance Insurance if they indeed did this. Most of the buyers are incapable of driving a camry. Now put them behind the wheel of 500. I wouldn't insure them.
About muscle cars, I believe I'm correct in saying that a base engine C6 will outrun a late 60's early 70's muscle car at the drag strip. So $650 a year for an 08 base car that is also a "muscle" car is not bad. I haven't told them I put a supercharger on it!!!
Based on GM's track record in the past of estimating conservatively either out of caution or deliberate sandbagging
I won't be surprised in the slightest if actual numbers are a little higher.
I won't be surprised in the slightest if actual numbers are a little higher.faninc
Banned Scam/Spammer
close
- Member SinceFeb 2007
Liked:708 Times in 404 Posts
Hi,
By artificially restricted...do you mean chevy would "detune" rather than maximize the HP it could get , stock?
I do wonder how turn key canned tuners are able to "find" 20 hp and 25 lbs torque with no mods...did chevy hold back maximizing their own brand new engine?
Quote:
All in all for the VVT alone we know the low/mid range doesn't have to sacrifice much while still keeping a great high end. It's going to be a very fast car, even if it is restricted to 450/450.
I'm interested in the aftermarket potential without completely losing its designed driving charactaristics. If tuners make an ecu breakthrough by chance in the first year, watch out. Intake, headers, cam, exhaust, and tune? ****... It's going to make a monster.
You're right. It is truly the under curve performance that matters most, but without completely dissecting the power curve and having access to a dyno, we can only assume the great benefits of VVT as have been witnessed on other manufacturers vehicles. The difference being here that the peak is one part of the picture and highly unlikely that the under-the-curve figures will resemble anything similar to what a typical 450 hp Chevy engine would. The point is, this is not a traditional setup, and the sum of the changes are truly going to be measurable both under the curve and at the higher end. Any reason this engine is not at 470+ hp right off the bat will be completely tune dictated and kept conservative for future room for growth as others have stated. There is little doubt, this engine will be capable of very strong numbers stock. No point forging a bottom end and changing bearings for small increases in output potential. I'd say the design would be overkill otherwise. the beefing up certainly hints at the engines capability being much more than it's predecessor. Anything under 470 hp will be artificially restricted, held back for purposes most likely due to marketing.All in all for the VVT alone we know the low/mid range doesn't have to sacrifice much while still keeping a great high end. It's going to be a very fast car, even if it is restricted to 450/450.
KenHorse
close
- Member SinceAug 2007
- LocationI live my life by 2 rules. 1) Never share everything you know. 2)
- Veteran Field #1St. Jude Donor '11-'12-'13, '16-'17-'18
Liked:2,433 Times in 1,376 Posts
Gotta love it when a thread that's older than a year is resurrected from the dead
Quote:
That is only 5 HP. Just adding the exhaust already brings the HP up to 460.Originally Posted by keagan
Doubt anywhere that high. I'm thinking 465 the most but even that I would say is too much. Let's just wait and see, they said closer to production we will know.
faninc
Banned Scam/Spammer
close
Hi,
When Chevy rates the Corvete C7 HP they are not doing to the rear wheels, correct? So when you dyno the car you get the lower than advertised number because to the rear wheels...how do you then convert that number to tell if numbers are underrated to Chevy's HP numbers? Do you add a 10% or 15% for driveline loss, to get back to the Chevy HP figure? Just curious...
faninc
Banned Scam/Spammer
close
A Diablo tuner post shows a dyno chart of their tuned results on A6 C7 that reads 432 HP made.
If you assume a 15% driveline loss for an auto trans, is it fair to say the engine after their tune is 496 HP (to the flywheel) vs. the advertised 455 HP Chevy advertised engine figure?
BTW, I am told everyone only cares about the HP to the rear wheels...so why do companies publish only HP numbers to the flywheel? (Besides the fact they are higher numbers?)
thanks!
thanks!
thanks!
Diablo dyno numbers are 412 RWHP stock and 432 RWHP after tuning. If the stock engine puts out an advertised 455 BHP the 412 RWHP translates to about 9.4% parasitic driveline drag. So that would be about 472 BHP or so for the new numbers. The parasitic drag on manual tranny cars will be even less. Originally Posted by faninc
A Diablo tuner post shows a dyno chart of their tuned results on A6 C7 that reads 432 HP made.If you assume a 15% driveline loss for an auto trans, is it fair to say the engine after their tune is 496 HP (to the flywheel) vs. the advertised 455 HP Chevy advertised engine figure?
thanks!
