Driving the Final prototype on GT5
Anyway, I upgraded the sport hard tires to sport medium and did an oil change. I was thinking that since the prototype doesn't say it's a Z51 and Z51 has better suspension ediff, customized tires for the Z51 etc. So I'm wondering if me upgrading to a sport medium from a sport hard would be a comparable upgrade to make it kind of equal times to what a Z51 would run???? (not a race tire of any kind)
Anywho, I ran on Laguna Seca about 10 laps (it took about 8 or 9 before I finally didn't go off in turn 2
) and I got the car to run a 1:35.695, which seems damn fast especially considering I'm not a good driver on there yet and I can tell there's a lot more in it.My main question is how much of a difference the sport medium tires are and I'm just trying to use the game to figure out what the real Z51 would run at Laguna Seca, but more importantly the Ring.
Love to hear any impressions and times everyone else has.
BONE stock, I've run 7:35.783 at Nurburgring...no oil change, no tire change, manually shifting with a clutch, etc. If I put on the tires you did and did an oil change I'd get 7:20's easy...that's Carbon Z06 range...I don't know about that.
I don't care for a few aspects of the game compared to Forza. The line on here seems to be wrong several times. Tells you to brake a tad before a corner you can easily drive through. Doesn't tell you to brake on a few other corners, and I totally fly off the track and slam into the wall every time. The car seems to turn kind of "choppy" for lack of a better word at times. I have no problem holding traction on turns after the straight doing 150+ through turns, but some turns that aren't that tight, the car flys off the track doing 70 or so. Anywho...
I just need more "seat time" to get it all figured out.
I tested car on Trial Mountain. At first corner I was on the inside too much; understeer is gone which was quite strong with previous version. The actual laptimes are close but car feels so much more controllable. Then to ugly part.. Car feels like it only has four gears, but then you find out there is three more to go. Gears just are too tall above 3rd. Motor is very strong. I was doing about 300 km/h in Mulsanne when I shifted to 6th!! Car kept on pulling to 320 km/h before I had to slow down. When doing 240 km/h motor was at 2400rpm with 7th gear!
I understand the overdrive of 7th gear but 4ht 5th and 6th are also too tall.
For reference my best time at Trial mountain was 1:37.4.
It could have used a bit more locking from the diff at exits but the torque is pretty brutal anyways.
He reminded me that the only way to get faster laps around the ring was more laps around the ring. No substitute for practice.
He reminded me that the only way to get faster laps around the ring was more laps around the ring. No substitute for practice.Just thought I'd ask.
). He did say he was looking very forward to finding out though.
One quality review of the model:
http://www.gtplanet.net/forum/showth...57#post8011757
HP: 464hp
TQ: 475lb/ft!!
Kerb: 1500kg or 3307lbs
Balance: 49/51
fuel cut: 7000rpm!!
I will easily believe the HP number and Kerb and balance but...7000rpm fuel cut? I thought it was 6600rpm redline and cut. And that torque...more than Z06!
