Differential
Old Jan 19, 2013 | 06:13 PM
jimc62k7's Avatar
jimc62k7
Default Differential
I'm not a mechanic but I thought a mechanial limited slip diff (base c7?) was better than an electronic limited slip diff (c7 z51?)
The Lexus IS-F went from an e-diff to non e-diff and handling/lap times improved.
Any thoughts?
Old Jan 19, 2013 | 06:21 PM
VetteDrmr's Avatar
VetteDrmr
It depends on the "e" in e-diff. BMW has a "limited slip" diff that is electronically controlled. That is, until you learn that the way it works is by the brake system applying the brake on the unloaded wheel. IOW, when you're trying to put power to the rear wheels, the brake system is counteracting that on the inboard wheel (assuming that's the one that's unloaded). In this case the mechanical LSD will be superior to the BMW's e-LSD.
OTOH, from what I've read, the C7's e-LSD is a mechanical LSD that has electronically controlled hydraulic clutch packs. If this is correct then it should be better than a traditional clutch pack, if only because of the dynamic aspect of the diff.
HTH, and have a good one,
Mike
Old Jan 19, 2013 | 06:23 PM
Bucknut2006's Avatar
Bucknut2006
Any thoughts?
The McLaren MP4-12C has an e-diff I believe as well as other high end performance cars. One properly implemented should be superior since it can be directly tied into the body control module. The system no longer has to guess what the diff will be doing.
Old Jan 19, 2013 | 07:59 PM
ivanjo11's Avatar
ivanjo11
The Electronic differential should allow the C7 to better put the power to the ground exiting corners.
Ferrari 458 has it and they said it shaves a few seconds at Fiorano, 911 also has it.
Old Jan 19, 2013 | 08:22 PM
theseal's Avatar
theseal
If it is f1 quality, literally, then it sucks bad because it will improve a few hundredths per lap for a great driver, (help alot for idiots) take up added weight, and then fail right after the warranty. If it is less than f1 quality tech, then it will slow down a great driver substantially and **** them off infinitely, help crappy drivers a little, add weight and fail right after the warranty.
This is the grossest kind of negligent overreach by electrical engineers and insurance people, against the interests of real men, mech engineers, people who plan to keep the car a while, and drivers who have pride.
Old Jan 19, 2013 | 08:39 PM
DREAMERAK's Avatar
DREAMERAK
St. Jude Donor '12-'13-'14, '16
it's one of the things that allows the 3850lbs GTR (not a fan) to turn the times it does.
Old Jan 19, 2013 | 10:17 PM
_zebra's Avatar
_zebra
what about a fully-mechanical style without clutch packs to wear out?
the TrueTrac from Eaton has been widely successful at working well and having great street manners
how it works:
To Differential
