Differential ratio?
Old Jan 27, 2013 | 01:39 PM
vettenutchas's Avatar
vettenutchas
Default Differential ratio?
Now that the C7 has gone to a 7 speed manual trans does any one know what the rear end ratio is compared to the manual C6?
Old Jan 27, 2013 | 01:42 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
My recollection is that it is 3.42 : 1. Same as the C6.
Old Jan 27, 2013 | 01:52 PM
vettenutchas
Maybe they changed the internal transmission ratios to gear it down a little in the lower gears for better acceleration!
Old Jan 27, 2013 | 01:57 PM
JoesC5's Avatar
JoesC5
Nope. First through sixth ratios remain the same. They only added an extra overdrive gear to increase the highway gas mileage.
Old Jan 27, 2013 | 06:31 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
The Z51 transmission is geared lower across the board except 4th is 1:1 in both versions.
To Differential ratio?
