Does thr automatic have the......
Old Feb 6, 2013 | 06:32 PM
Gonzo's Avatar
Gonzo
Default Does thr automatic have the......
Functional rear vents????
I know the Z51 has one that cools the diff and one that cools the transaxle. Does the Autmatic have this and can you get automatic as a Z51????
I would like a Z51, but automatic seems like a better idea at this point in my life.
Gonzo
Old Feb 6, 2013 | 06:45 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I would think that as long as you order the Z51 option be it the 7-speed or the 6-speed auto the vents are there.
Old Feb 6, 2013 | 07:54 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Gonzo
One vent is used to cool the automatic transmission regardless of trim level. Both vents are used with the Z51 option. And yes you can get the automatic with Z51.
Old Feb 6, 2013 | 08:02 PM
CGZO6's Avatar
CGZO6
Vents are gonna be there whether you get z51 or not. One part is cheaper to produce. The z51 cars will have the diff and trans coolers
Old Feb 6, 2013 | 08:10 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Diff and trans axle are one and the same. Auto trans Z51 are bad *** cars with dry sumps and all the goodies...
Old Feb 6, 2013 | 08:12 PM
BucketList's Avatar
BucketList
Cant wait to get my paws on a C7 Z51 and run some good twisties........ Gonna be a BLAST !
Old Feb 6, 2013 | 08:13 PM
BlueOx's Avatar
BlueOx
This...working vents. If you order the base, I think only one side's vent really works.
Old Feb 6, 2013 | 08:21 PM
JoesC5's Avatar
JoesC5
Since GM has designed all those tacky black plastic vents on the car to be functional, does that mean a base C7 with auto, is going to be faster on one side vs the other side with a non functional vent or that the down force will be greater on one side of the car vs the side without the functional vent. Seems that if the C7 needs all those vents to make it stable at high speeds(vs the C6 Z06 and ZR1 without the vents), then the car must be very unstable if one side of the car has a greater down force then the opposite side of the car, and one side of the car slips through the air faster then the other side of the car.
Old Feb 7, 2013 | 10:12 AM
CGZO6's Avatar
CGZO6
The vents are functional on all stingrays, whether the heat exchangers for the diff and trans are there is a matter of z51/base selection. I also believe the fender vents are providing cooling air for the rear brakes, but I can't find a confirmation on this.
Old Feb 7, 2013 | 11:06 AM
JoesC5's Avatar
JoesC5
There are some earlier posts that said the rear vents are blocked off if not required.
If true that would mean that.....
both rear vents blocked off in a base car without an auto.
one rear vent blocked off in a base car with auto trans.
one rear vent blocked off in a Z51 car without an auto trans.
no rear vents blocked off in a Z51 car with an auto trans.
CitationZ06@yahoo's Avatar
CitationZ06@yahoo
They have ducts under the car that feed brakes, like on the ZL1
Old Feb 7, 2013 | 11:18 AM
jkcam6017's Avatar
jkcam6017
Joe, why all the anger?
Some people love tacky black plastic vents, and GM had determined that they are the people with money.
Yes, the car will go faster on one side, but it is the opposite side as the driver. So only if you are riding around with a beefed up passenger will the car go in circles.
Old Feb 7, 2013 | 11:20 AM
JoesC5's Avatar
JoesC5
On the C7, the front brakes are cooled by ducts located in the grill at each end, and the rear brakes are cooled by ducts located under the car.
Old Feb 7, 2013 | 11:26 AM
JoesC5's Avatar
JoesC5
Just think how much faster I'll be able to drive around Talladega(vs the slow *** 162 MPH in my C6 Z06) with the right side of the car going faster then the left side. No worries about hitting the wall. It will be like I'm on rails. Go C7. just like the NASCAR Cup cars. Shove that accelerator pedal to the floor an never let up, all the way around the track.
Bad thing is no 1/4 mile drags, as I won't be able to keep the car in it's lane, and will be thrown off the track.
Old Feb 7, 2013 | 12:38 PM
Kappa's Avatar
Kappa
Yup, the aero work should make it more stable than the C6 Z06 and ZR1. Good thing the engineers decided to make a point out of that. Hope you don't mind.
Old Feb 7, 2013 | 01:47 PM
JerriVette's Avatar
JerriVette
Bill,
Good to hear the automatic Z51 gets the dry sump engine as well...
Thats an change from the c6 grand sport manual and automatic transmission...
I guess the handling improvements of the z51 require the dry sump system...
To Does thr automatic have the......
