Launch Control
Old Feb 14, 2013 | 09:28 AM
G352C6's Avatar
G352C6
Default Launch Control
Does the C7 get launch control? Was it ever available on the C6?
Old Feb 14, 2013 | 09:33 AM
AVETTE's Avatar
AVETTE
Cruise-In II Veteran
Cruise-In III Veteran
Default launch control
I believe it does, and it was not on the C6 except on ZR1 and maybe late model z06 (not sure about z06)
Old Feb 14, 2013 | 09:49 AM
BRCC's Avatar
BRCC
Launch Control was available on ALL 2010 and later Corvettes with a manual transmission.
Old Feb 14, 2013 | 10:21 AM
Larry/car's Avatar
Larry/car
It will be on all C7's. I am not excited about launch control. It is OK, but I would rather do it myself - HA! = Fun Factor..
Old Feb 14, 2013 | 10:30 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
C7 will get launch control. Yes, all manual transmission C6 Corvettes starting in 2010 have launch control.
Old Feb 14, 2013 | 10:20 PM
Flex182's Avatar
Flex182
nice, glad its getting it
Old Feb 15, 2013 | 07:23 AM
redzone's Avatar
redzone
All C7's? Or just the manuals?
Old Feb 15, 2013 | 07:33 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
All C7 MANUAL TRANSMISSION CORVETTES WILL HAVE LAUNCH CONTROL.
Old Feb 15, 2013 | 07:41 AM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Interesting the automatic and the standard come with launch control. Checking the Corvette brochure..when a feature is limited it is noted in the brochure. Plus one of the videos referred to it. New cars bring new things. It may also be the reason they did not go with 8 speed automatic. Launch control can shock the transmission.
Old Feb 15, 2013 | 01:07 PM
LIVetteFan's Avatar
LIVetteFan
Unless somethings radically changed for the C7 only the manual will have LC. In the 2010+ manual transmission cars the LC was enabled by holding the engine RPM at 4K and dropping the clutch and the computer would modulate engine rpm/torque to available traction. That mechanism is obviously incompatible with an auto. LC is not Traction Control...
Old Feb 15, 2013 | 01:18 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
No sh#t Sherlock. I guess I am testy today. Long before they had launch control on stick shift cars they had it on automatic drag cars. The ability to dial in the rpm of the launch has been done for many years in automatics. I think because you know how one type of launch control works, that is how it has to work for all transmissions. This is a lesson for you..try not to make assumptions. Check out your facts, then make your conclusion.
Old Feb 15, 2013 | 02:50 PM
speedlink's Avatar
speedlink
Yes launch control was available on 2010 and later models.
It will probably be available on C7 as well.
Old Feb 15, 2013 | 02:52 PM
speedlink's Avatar
speedlink
Old Feb 15, 2013 | 03:38 PM
LIVetteFan's Avatar
LIVetteFan
Excuse me, nowhere did I mention any other transmission than the one in a 2010 Corvette. Lesson for you, try not to be such a troll.
Old Feb 15, 2013 | 03:48 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
How does launch control work on a manual?
Old Feb 15, 2013 | 04:22 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Excuse me..." Unless something's radically changed for the C7 only the manual will have LC"
Your words. You can call me anything you want. I could care less. You can't change what you wrote. Lesson for you on the use of posting on the Internet. Try harder.
Old Feb 15, 2013 | 05:06 PM
Zymurgy's Avatar
Zymurgy
Moderator
Unless somethings radically changed for the C7 only the manual will have LC....
Something has radically changed. From the "Return of the Stingray: The 2014 Chevrolet Corvette" press release dated Sunday, Jan 13, 2013, 7 p.m. EST:
"Launch control: Available in Sport and Track modes for manual and automatic transmissions, providing maximum off-the-line acceleration"
To Launch Control
Old Feb 15, 2013 | 05:41 PM
arkus's Avatar
arkus
lunch control
Old Feb 15, 2013 | 08:27 PM
b4i4getit's Avatar
b4i4getit
I have it on my Z06. Its no big deal and I certainly would not miss it if the C7 did not have it. Its just a marketing point.
Old Feb 15, 2013 | 08:30 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
to major Tom.
