"strobe" brake lights?
Old Feb 20, 2013 | 01:07 PM
ecarbone's Avatar
ecarbone
Default "strobe" brake lights?
Check out this youtube video. Comments?
Old Feb 20, 2013 | 01:21 PM
kon_gee's Avatar
kon_gee
It is caused by the video camera's shutter speed running in & out of sequence with the LED's frequency. You see similar illusions when video camera's make wheels look like they are spinning backwards by the shutter speed. Video camera's do the same thing when they record a TV in action.
Old Feb 20, 2013 | 01:22 PM
TorqueDriver's Avatar
TorqueDriver
That "strobe" effect you are seeing is due to the videotaping of LED lights.
You won't see it otherwise.
Old Feb 20, 2013 | 01:46 PM
JimmyLee's Avatar
JimmyLee
I was thinking that strobe tail lights would be great for the occasional rave party or for giving the mother-in-law an epileptic seizure.
Old Feb 20, 2013 | 01:47 PM
Zymurgy's Avatar
Zymurgy
Moderator
This is the same type of effect you get if you shoot video of a TV screen. This is not an issue.
Old Feb 20, 2013 | 01:51 PM
Process Black's Avatar
Process Black
Here's the same video/LED out of sequence example with the ferrari 458.
36 seconds in.
Old Feb 20, 2013 | 03:27 PM
Mike Mercury's Avatar
Mike Mercury
seems the same people get confused between a photo and a rendering...
Old Feb 21, 2013 | 01:02 PM
ecarbone's Avatar
ecarbone
I understand why the strobe effect is there on non-tungsten lighting utilizing AC voltages but a car is DC and the LED uses DC voltage, not AC at 60hz. Still don't understand the strobe effect on a stationary object such as the Corvette is in this clip.
Old Feb 21, 2013 | 01:37 PM
Zymurgy's Avatar
Zymurgy
Moderator
Perhaps the LED drivers use Pulse Width Modulation (PWM). PWM turns the LEDs on and off and can be used for dimming, or to control the amount of power delivered without using resitive means. PWM is more efficient than using resistors.
Old Feb 21, 2013 | 01:52 PM
wlutgen's Avatar
wlutgen
The LEDs in car taillights have circuitry added to strobe them as a method to vary their brightness. It's called Pulse Width Modulation if you want to Google it.
The frequency of the pulsing should be fast enough (say 100 Hz) so that it's not noticeable when you look at it in person (although I do notice the flicker in some tail lights when I move my eyes quickly).
Some video cameras, especially cheap ones, only hold their shutter open for an instant when they capture a frame. Even though they're capturing at 30 Hz (for example), they may only hold the shutter open for 1/100th of a second every 1/30th of a second. Sometimes then this fast shutter catches the LEDs in their "off" state and magnifies the apparent time that they are off from 1/100th to 1/30th of a second which is slow enough for you to see it.
Old Feb 21, 2013 | 02:04 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
I can't believe people are still asking this question and actually believe that the tail lights will really strobe like they do in this single video.
With the strobing tail light option, you get a mini-disco ball to hang off the rearview mirror.
S.
Old Feb 21, 2013 | 02:18 PM
Tri-Tip's Avatar
Tri-Tip
If the tail lights did strobe, it would be pretty rice-y.
Old Feb 21, 2013 | 02:53 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
But they don't, so it is a moot point.
Old Feb 21, 2013 | 03:09 PM
wishihad1-2's Avatar
wishihad1-2
There are actually two reasons why the LEDs would be strobed. The first was already mentioned, to make the LEDs appear to run at something less than full bright. This allows the same actual LEDs to be the running and braking lights. With conventional bulbs you either use two (or more) bulbs or have a dual filament bulb.
The other reason to pulse LEDs is because you can actually drive them brighter that way. For what ever reason you can get more average light out of a red LED if you over drive it then turn it off for a moment. I don't remember the details of this as it was over a decade ago I looked into it. Anyway, I know the earliest automotive LEDs were driven this way since otherwise the red LEDs weren't bright enough. I assume they still do it since it would allow you to use lower cost LEDs that aren't as bright.
Old Feb 21, 2013 | 04:10 PM
MikeG37's Avatar
MikeG37
S.
I can't believe so many people are somehow just seeing this video effect for the first time. I remember wondering (and google'ing) what caused it when the first videos of the then new 458 began to circulate.. and that was about 4 years ago.
Old Feb 23, 2013 | 03:36 AM
vetteman741's Avatar
vetteman741
From: Motorsports Capital of the World..Indianapolis Indiana
Great, now i watched the video and have DIO Holy Diver stuck in my head
OMFG over and over, really, I wouldn't even be able to speak, just trying to breathe and not tear up when I see the first one
Corvette is my PASSION
Oh yeah, not to be off topic......strobe light=rice and doubtful
Old Feb 23, 2013 | 10:48 AM
DRLC5's Avatar
DRLC5
Some of the newer Porsche's and MBs are coming with this from the factory. I see a Porsche in my area that has them?
http://api.viglink.com/api/click?for...13616344427685
Old Feb 23, 2013 | 05:15 PM
range96's Avatar
range96
Flashing LED and strobe light are NOT the same thing. I venture to say we'll see real strobe brake lights (activated by hard braking) in the future.
Imagine a KIA trying to slow down behind a car with CC brakes.
To "strobe" brake lights?
