I need more info on the C7 transmissions. With the rev matching on the manual, it sounds as though you can shift without using the clutch. Is this true? On the automatic, will it automatically up shift at a certain RPM evan if it is in manual mode? The Camaro is that way and I don't like it at all. Is the auto new as compared to the C6? I guess it must be as they only used 2 bolts from the C6.
On the Z51 package, has any one heard what the gear ratios are?
All the rev match feature does is blip the throttle to simulate heel-toe shifting. It would be very cool if you didn't need to use the clutch but those transmissions are more commonly known as DCTs and we, unfortunately, don't have that option.
DCTs have clutches, just computer controlled. Theoretically, if you have the speeds perfectly rev matched (hence the term ) then you don't need a clutch and it should move from one gear to the next sans clutch (i.e. there would be no need to decouple the engine from the transmission because they would be both moving at the same speed). Don't know if the new MT can do that, I sure as hell cannot!
I guess what I meant is that with a DCT, you don't physically control the clutch... not that there is no clutch.
The rev match feature does not, to my knowledge, negate the need to use the clutch. Other cars have this feature and you still have a need for a left foot
no, you still have to use the clutch on a 370Z and Porsche w/ the rev match feature (unless you're Cale Yarborough who, if memory serves correctly, destroyed a Jag's gearbox during some car mag's comparison test. He claimed something to the effect of "I've never used a clutch on a racecar before, why the hell should I start now?").
It would be awesome if you could just bang the shifter and skip the manual clutch work altogether but then you'd be using a X-Trac
Still waiting to hear all the ratios of the base 7-speed manual and the Z51 7-speed manual. A while ago someone said the ratios are the same as the 6-speeds were but with a tall 7th gear added. Nobody verified that. Has anybody found the ratios, I couldn't?
TR6070 has the same ratios as the TR6060.
base C7 has the same 1st thru 6th as the base C6/Z06 but with a .42:1 7th gear, and the Z51 has the same ratios 1st thru 7th as the C6 Z51/GS but with a .48:1 7th gear.
No performance change in the transmissions, just a tall 7th gear for highway gas mileage.
Thanks for the verification Joe Now I can put them all down in order:
In past years cars with the aggressive 2.97 first gear have always felt noticably livelier at lower speeds than base cars with the taller 2.66 gearing... Except C6 Z06s. With all that extra torque the 427s seem to feel plenty strong even with the taller gearing. Now the Base C7 has lots more torque, supposedly comparable to the 427 below 4000 rpm. It will be interesting to see if the C7 needs the aggressive gearing option as much as the C6 did.
The 2008-up TR6060 with 2.66 1st (MM6) has a maximum torque rating of 500 ft lb. The TR6060 with 2.97 1st (MZ6) has a maximum torque rating of 428 ft lbs. Safe to say the C7 Z51 TR6070 will see some extra beefing up/hardening.
Which Camaro is that way? The V6?
In my G8 the car will not shift up in manual mode unless you tell it to. It will bang off the limiter all day long in manual mode. It will only shift down to prevent a stall.
The auto transmission in the Corvette is the same that's in the G8 and the Camaro AFAIK.
