Roadster heat problems?
Old Mar 12, 2013 | 08:43 PM
Rowboat66's Avatar
Rowboat66
Default Roadster heat problems?
What with the new hood vent taking engine heat over the top of the car rather than under the car as in the C6... will the top-down driving experience include a very warm back-wash in the cabin?
Old Mar 12, 2013 | 08:51 PM
RicK T's Avatar
RicK T
One would hope that was thought about and addressed in the design process.
Old Mar 12, 2013 | 08:57 PM
RJRSW's Avatar
RJRSW
Shouldn't be a real problem as the air coming out the hood vent only passed through the radiator and the engine compartment is separated and will vent under the car and possibly some through the side fender vents.
Old Mar 12, 2013 | 09:03 PM
lt4obsesses's Avatar
lt4obsesses
This, and much of the heat should be dissipated by the time it gets over the windshield.
Old Mar 12, 2013 | 09:06 PM
BlueOx's Avatar
BlueOx
I'm not real worried.
On cold days that would be a good thing if it did happen that way. On warm days you could always turn on the AC if necessary.
Old Mar 12, 2013 | 09:09 PM
janky's Avatar
janky
not according to this...
Rowboat66's Avatar
Rowboat66
Doesn't the heat from AC also go topside?
Old Mar 12, 2013 | 09:11 PM
michaelinmech's Avatar
michaelinmech
Actually the design of the aerodynamics, according to the C7 design gurus, is that the air exiting through the hood vent is routed around the sides of the car. This is true for both coupe and convertible. So perhaps there will be slightly warmer air passing by the side windows, or window openings.
Ferrari, McClaren, Viper and others are all now using the lay forward radiators and hood vent design - track derived technology brought to the street
Old Mar 12, 2013 | 09:13 PM
BlueOx's Avatar
BlueOx
As was said before, IMO the vent only goes through the radiator.
What I'm curious about is will the console of the C7 be as hot as the console of the C6 has been.
Old Mar 12, 2013 | 09:32 PM
slief's Avatar
slief
I also understand that only some but not all of the air flow is sent through the radiator. The rest has a clean path out the hood. In looking at photos of the engine and the duct, I wonder if the duct even see's any of the radiator air.
Looking at this photo of the engine compartment and the angle of the duct:
This photo of the frame, you can see the radiator rack.
I can't help but wonder if the air that flows through the radiator is exhausted out below the car or into the engine compartment and then through the side ducts instead of out the hood.
Old Mar 12, 2013 | 09:43 PM
michaelinmech
The air directed through the top forward leaning radiator exhausts through the hood vent - engine compartment heat is exhausted elsewhere
Old Mar 12, 2013 | 09:46 PM
RJRSW's Avatar
RJRSW
"GM explains the many vents of the 2014 Chevrolet Corvette Stingray
In the 2014 Corvette, the air passing through the radiator is channeled quickly up through the opening in the front portion of the hood. This prevents that hot air from gathering around the engine so the heat is removed more effectively. Also, the turbulence created by the cooling air “trapped” in the engine bay can cause front end lift while the cooling system of the 2014 Corvette actually provides better downforce at higher speeds."
http://www.torquenews.com/106/gm-exp...ray-new-videos
Old Mar 12, 2013 | 09:49 PM
michaelinmech
That's what I said - twice
Old Mar 12, 2013 | 09:53 PM
Rowboat66's Avatar
Rowboat66
From the OP, Thanks all.
Old Mar 12, 2013 | 09:54 PM
janky's Avatar
janky
Given that the exhaust is now routing INSIDE the center tunnel, it's going to take some doing to prevent that heat from transferring at least as readily as before.
Old Mar 12, 2013 | 09:57 PM
RJRSW's Avatar
RJRSW
I have always been a little surprised when people post about how excessively hot their console gets.
I live in Tucson and it gets pretty warm here in the summer and I never have had a problem with excessive heat in the console. Are the people that are having problems with that running headers are some after market exhaust system?
My car is totally stock and it just never gets too hot in my car's console even in mid summer with the top down.
Old Mar 12, 2013 | 10:05 PM
michaelinmech
The C7 Design Gurus has said that they are employing an insulating material in the tunnel to address the heat issue. I do not have the technical info - perhaps another member can refer us to it
To Roadster heat problems?
Old Mar 12, 2013 | 11:17 PM
jackhall99's Avatar
jackhall99
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Much ado about nothing, or some overly sensitive people driving Corvettes.
Old Mar 12, 2013 | 11:26 PM
JustinStrife's Avatar
JustinStrife
I don't notice it either and I've spent some time in 110+ degree heat in Lake Havasu. My stroked, blown 402 doesn't cook that console at all.
Old Mar 12, 2013 | 11:48 PM
User 2623's Avatar
User 2623
I have voiced the same concern, but in order to reduce heat in the cabin with the C6 additional sheilding was needed around the transmission below the center console. I'm not sure how all this venting addresses this problem.
We'll see .....
