C7 - Mid or Rear Engine
Old Mar 14, 2013 | 12:17 PM
Navy01Coupe's Avatar
Navy01Coupe
Default C7 - Mid or Rear Engine
It seems that the last few years lots of rumors have bounced around about going to a mid or rear engine in the C7. I found the quote below in a Car and Driver magazine article from September 1969 when discussing the 1970 Corvette.
"The present Corvette will doubtlessly be the last front-engine model. It remains uncertain if the new rear-engine version will be introduced in 1971 or 1972 (a great deal depends on Ford and its rumored rear-engine sports car)."
Old Mar 14, 2013 | 12:20 PM
dmporter31's Avatar
dmporter31
great find. Guess no one at GM got the memo............
Old Mar 14, 2013 | 12:30 PM
petermj's Avatar
petermj
If I recall, there was a follow up memo forwarding the design to John DeLorean and his Fiero team and postponing rear mounted mid engine for Corvette to C15 or C16 (combined with vertical take off and supersonic flying abilities at that time). But hey, apparently the Vette is already mid engine configuration, based on a technicality of the definition.
Old Mar 14, 2013 | 01:25 PM
RocketGuy3's Avatar
RocketGuy3
Hah, that quote is gold.
Old Mar 14, 2013 | 01:34 PM
michaelinmech's Avatar
michaelinmech
And then along came the gas crisis of 1973 followed by a second in 1979 and all Detroit development dollars shifted to econo-boxes
Old Mar 14, 2013 | 01:36 PM
janky's Avatar
janky
Ah yes, back when mid-engined was considered the new standard for everything performance oriented because of the Miura. It ended up not being ideal for the vast majority of vehicles, engines are still too large and servicing them is a PITA.
Old Mar 14, 2013 | 01:55 PM
petermj's Avatar
petermj
This is another good one
"DETROIT – Few new cars have ever caused the stir that whipped up around the 1990 Corvette ZR-1. It started with fuzzy spy photos and Detroit gossip about a high-powered, “King of the Hill” model. Chevrolet was coy, neither confirming nor denying the grist of the rumor mill.
Rumor became fact at the 1989 Geneva Auto Show, when the ZR-1 officially debuted. It was a time when performance cars were only beginning to regain some of the performance enjoyed during the heyday of the muscle car, and the ZR-1's 375-horespower (280 kW) LT5 V-8 engine – with its DOHC configuration and four-valve heads – was an intoxicating breath of high-octane excitement.
The all-aluminum LT5 engine's design was a collaboration of GM and Lotus Engineering, sharing only a 5.7-liter displacement with other small-block engines. The engine was built by Mercury Marine, which was renowned for its aluminum machining capability. Engineers were justifiably proud of the LT5's refinement and smoothness; so much so that it was claimed a nickel placed on its end on top of the engine wouldn't fall over when the engine was started. The challenge was immediately taken up – and the LT5 roared to life while the nickel remained standing"
To C7 - Mid or Rear Engine
