Removing Weight From The C7/LT1...
You know what Occam's Razor is? If you cannot fix the source of vibrations, you remove the part that causes them, you know, like they did with C6R. What are the actual fuel economy benefits on C7 vs. complexity and problems it adds? GM is not only lazy, it is also very stupid. C7 is a very aerodynamic shape, just like C6, once it rolls on the freeway at constant speed, it makes very little difference on how many cylinders it runs.
Glad you picked up a new buzzword in the other thread but im pretty sure logic/philosophy is lost on you entirely. The "razor"=simple>complex, common>rare, easy>hard etc...
so
AFM on a v8 that you know>developing a 500hp/30mpg boosted v6
Cheap steel that does its job perfect>driving cost up with needless engineering
keeping the price the same(adjusted for inflation) for 60 years>pricing your car out of the market you created because you over-engineer exotic materials when it does not make sense.
Believing you are chevrolet>thinking you are lamborghini
Knowing it didn't>hoping it cleared things up
Do not apologize, LOL. And sometimes good enough is just not good enough, especially when it is unnecessary to begin with. If Tadge is indeed a smart guy, he should grow some ***** instead of playing along propagating counterproductive and outright dumb ideas.
[QUOTE=HurricaneRN;1583455765][QUOTE]Originally Posted by petermj
so
LOL, yes, you cleared up everything.
so
You're correct. The engine materials are heavily rules controlled to avoid costly materials. But they were headed down a different road before this was the case, mostly metal matrix composites and Boron based materials....
LOVE the new C7
Bob
LOVE the new C7
Bob
The Lamborghini Aventador is now capable of shutting down an entire bank of its 6.5L V12...though most potential owners can't even pronounce the words "fuel economy". Most of them would probably feel that it would add cost (who cares?) and weight/complexity for no perceived real-world gain. In that market, it's unlikely that AFM will proliferate, unless it becomes desirable/demanded by the potential customers. It might happen, though...lots of people (in all income strata) like to feel "green" about themselves, whether they actually are or not. How else could the high-carbon-footprint Prius be explained? Or the coal-powered Teslas and Datsun Leafs (Leaves?)...
Corporate stupidity knows no limits. Assuming GM could actually make AFM really work, it belongs on vehicles with bad aerodynamics, like trucks and SUVs, where it is already being used. If you give it more thought, you will agree more, if you do not, I'll live Either Tadge is so dumb or so controlled by the forces above him, not sure how he can face himself on daily basis.
You obviously know best
Best of luck
The Consigliere
Received 5,445 Likes
True.
But he is marginally better than the dude that has himself apparently convinced that all of us here in C7 forum have somehow managed to deny him the option of awd and dct on what was clearly a "clean sheet" design, which not having such options is ab initio a complete fail.
I think I bolded all the right words and properly used the quotes. I've certainly seen it enough times (I believe quite literally dozens) that I should be able to do it by memory.
Seriously though, I understand completely why the engine weighs what it does...the car too, for that matter. I'm fine with both. I figure if it comes with wheels and tires on it, then I won't have to carry it around...so why should I care what it weighs? I posted the links and asked the "what about Holtzberg" question more in a "what if" frame of mind than to bash the car as is. The car's fine the way it is, mechanically speaking...
#34
Ah well at least I'm building muscle so my assistless and rough riding C4 won't wear me out
#35
Know the feeling man. I'm trying to drop 15lbs. I don't think it's going to happen until the warm weather hits and I can start cycling again. I'm told I look good for my weight and height, but I'm trying to shave abit of weight for driving purposes.
#36
Muscle is heavier than fat, but I've a little way to go before I can say it's all muscle
I can cut 15lbs, I know I can. It's just a matter of whether or not I feel like putting myself through freezing my ***** off and cycling in the winter or not. (which won't have the same results as cycling in the summer months anyway)
#38
There's water weight to consider too. There's also still abit of fat that needs to go too. If the snugness of my 30 jeans is any indication.
