Rev match?
Old May 30, 2013 | 11:09 AM
Spulbus2013's Avatar
Spulbus2013
Default Rev match?
Ok, so will this option be retained once you tune your car? what about once you supercharge or turbo it? what happens if you change the rev limiter? What about heads and cam? Very curious about all of this or should I say the whole NOT losing rev match at all. Thanks,
Old May 30, 2013 | 11:16 AM
Kappa's Avatar
Kappa
The only thing I can imagine changing it would be a new shifter or shorter gears.
Old May 30, 2013 | 11:22 AM
Supermassive's Avatar
Supermassive
Yes, yes, maybe, yes. The only thing that could affect rev matching would be rev limiter adjustments but I'm sure with some tweaking even those would be doable. Rev matching is done via sensors in the shift assembly that "predict" your next shift. These signals are then sent to the ECU which determines what gear you are about to shift into and how fast the engine should be revving in that gear at the speed you are currently traveling. Then the ECU tells the ECM to goose the throttle to the desired RPM while you release the clutch. All in a fraction of a second. It's pretty snazzy tech and a lot of fun...it also makes guys like myself who have monster feet and cant heel-toe to save my life look and sound much better than we actually are. Of course those that can heel toe are still at an advantage because rev matching isnt always perfect, especially when wheels start spinning...
Old May 30, 2013 | 11:25 AM
Spulbus2013
Thanks a lot fellas! So I pray the stock shifter has some feel to it and is great out the gate because if so then this C7 is shaping up to be a dream!
Old May 30, 2013 | 12:39 PM
es's Avatar
es
Never drove a car with rev match. Does anyone know how the match will work on upshifts? With foot flat to the floor can I just hit the clutch and go for the next gear without lifting off the gas?
Old May 30, 2013 | 12:50 PM
CPhelps's Avatar
CPhelps
I think what you are describing is "no lift shifting", which GM has had on a few vehicles but I have not heard mentioned for the C7.
Old May 30, 2013 | 01:04 PM
ck9887's Avatar
ck9887
No this is not rev matching...
Rev matching is used for down shifts. It basically revs to match engine speed with tranny speed to make the downshift much smoother. It's useful when coming into a corner hot as it doesn't upset the chasis or cause the back wheels to lock up for that split second.
You can rev match any car yourself using the heel-toe technique, it's just very difficult to do and takes a lot of practice.
Old May 30, 2013 | 01:24 PM
Kappa's Avatar
Kappa
The C7 is supposed to rev match on downshifts and upshifts. This is new. I'm wondering how it works in real life.
Old May 30, 2013 | 01:55 PM
es's Avatar
es
All the information that I have read says that rev matching is available on upshifts also - GM has touted patenting a new sensor on the shift linkage that works on upshifts. This is the basis of my question about keeping foot to the floor on upshifts. Will the sensor signal the system to drop the revs enough to match the rev needs of the next gear without buzzing the engine
Old May 30, 2013 | 02:12 PM
jcosta79's Avatar
jcosta79
I have a 370 Z with the rev-match feature. It does it on both downshifts AND upshifts.
If you're coasting for a bit and put the car in neutral, the revs obviously drop to idle. From neutral, the car does not automatically assume you are dropping into a lower gear, it simply senses which gear you are going into based on how you move the shifter. Once it determines which gear you are going into, it matches the revs accordingly, whether it's a gear lower or higher than the previous one.
Old May 30, 2013 | 02:19 PM
jcosta79's Avatar
jcosta79
Rev match will work on upshifts, but what you describe is no-lift shifting which is different. In the 370Z you will hit the limiter if you try this. You can manually over-rev the engine between shifts if you felt so inclined. It doesn't limit revs called for by your foot.
On upshifts, the computer will simply hold the appropriate revs for the next gear so that the engagement is as smooth as possible. I know it seems counter-intuitive, but the rev-match's usefulness becomes more apparent when driving lazily around town rather than when driving it hard on the track.
Old May 30, 2013 | 02:25 PM
jcosta79's Avatar
jcosta79
I'm not sure where you heard that GM is patenting a new sensor that works on upshifts. Once you put the car in Neutral the computer has no way of "remembering" what gear you were in (nor would it need to) and it doesn't assume which gear you are going to select next. It simply senses which gear you are going into based on shifter movement and revs the engine accordingly based on how fast the car is moving.
This feature has been available on the 370Z since 2008 (2009 model year).
Old May 30, 2013 | 02:41 PM
BlueOx's Avatar
BlueOx
This is one of those bits that GM better do a great job of training people to use. Using/customizing the Driver Modes, using Rev-Matching, using the Performance Data Recorder, etc, etc, are going to require a significant group of teaching tools to ensure customer satisfaction.
Old May 30, 2013 | 02:46 PM
jcosta79's Avatar
jcosta79
It should take a normal person all of 30 seconds to get accustomed to rev-matching. Seriously, it's not as "weird" as people are fearing.
Gas out - clutch in - select gear - clutch out - gas in.
Done.
Old May 30, 2013 | 02:51 PM
Matt Gruber's Avatar
Matt Gruber
does the rev-match help lazy shifts around town without the clutch?
Old May 30, 2013 | 03:05 PM
jcosta79's Avatar
jcosta79
Never tried it.
Old May 30, 2013 | 03:13 PM
BlueOx's Avatar
BlueOx
Done.
I don't think Rev-Matching will be hard to do, just a new approach to get used to and use effectively.
I still haven't even made up my mind if I'll get an auto or manual.
Old May 30, 2013 | 04:08 PM
joenationwide's Avatar
joenationwide
Done.
Thats a pretty ambitious learning curve. It takes a little less time than it takes you to learn to drive a manual car IMHO. Can be practiced on the street.
Yes. Both for upshifts and down shifts. I used to be so lazy (especially in stop n' go traffic) to shift maybe 20-30 times in a row without using the clutch.
Quick blip of the throttle to downshift.
Lift throttle, shift to neutral, pause, upshift.
No clutch at all. No grinding at all.
To Rev match?
