C6 wheels on C7
Old Jun 6, 2013 | 08:21 PM
AmmoVet's Avatar
AmmoVet
Default C6 wheels on C7
I have a spare set of wheels for my C6, will they fit on a C7?
They are the std 18 & 19 in size.
They have Bridgestone all season tires, would they also fit on a Z51 C7?
Old Jun 6, 2013 | 08:31 PM
rcallen484's Avatar
rcallen484
Base C7 is 18/19, Z51 is 19/20. Base C7 tire size is same in all regards as base C6, just Michelin Pilot Super Sport ZP instead of Goodyear RF. Not sure if wheel offsets are the same though.
Old Jun 6, 2013 | 08:53 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
If the wheel offsets are the same that would open up some really fantastic wheels. I am getting a Z51 and would love to run ZR1 rims.
Old Jun 7, 2013 | 05:00 AM
B Stead's Avatar
B Stead
We don't yet know what the C7 wheel offsets are.
But the 18/19 wheel set might not fit over the Z51 brakes
Old Jun 7, 2013 | 05:07 AM
JerriVette's Avatar
JerriVette
When does gm release wheel offset information?
Old Jun 7, 2013 | 07:05 AM
z edge's Avatar
z edge
i have heard of people putting the newer model wheel on the older car, but never the opposite.
Old Jun 7, 2013 | 08:49 AM
Dominic Toretto's Avatar
Dominic Toretto
Is this thread serious or just another attack at the C7 tire size issue?
-Alex
Old Jun 7, 2013 | 09:49 AM
JerriVette's Avatar
JerriVette
It's a serious issue for those that have c6 wheels with winter tires on it and hopeful to use the same for the new c7 during winter months...
Old Jun 7, 2013 | 09:59 AM
690 HP V's Avatar
690 HP V
I wonder about C7 wheels o na C6 actually. They are like the same bolt pattern so the offset will be the only question.
Old Jun 7, 2013 | 10:13 AM
AmmoVet's Avatar
AmmoVet
Serious question.
I guess it boils down to finding out if the offset is the same.
Plus the TPMS would be the next issue. Surely they will not be compatible so at the minimum another set of C7 TPMS would need to be placed in the older tires.
Old Jun 7, 2013 | 05:45 PM
theseal's Avatar
theseal
Offset is most likely very close. I assume bolt pattern and center would not change. The question is caliper clearance and wheelwell room. No way to know unless you have a car in front of you.
Old Jun 7, 2013 | 06:34 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Old Jun 7, 2013 | 06:50 PM
JerriVette's Avatar
JerriVette
Would a wheel spacer work if caliber clearance was an issue?
To C6 wheels on C7
