Programming options
Old Jul 2, 2013 | 06:37 PM
C7s's Avatar
C7s
Default Programming options
Does GM have a way to program different settings? For example remove seatbelt chime, adjust headlight on sensitivity, check error codes, etc. On my Audi I program the car using a VagCom cable and software on my labtop. What can you use on a GM car?
Old Jul 2, 2013 | 09:52 PM
BRCC's Avatar
BRCC
Not known at this time, but I doubt some of those are going to be available, judging from the past C6.
Old Jul 2, 2013 | 10:00 PM
AVETTE's Avatar
AVETTE
Cruise-In II Veteran
Cruise-In III Veteran
Default Search the forum...
There is a guy on the forum (in Michigan I think) that offers several programming options, the stuff I am sure of relates to the new mylink system, as an easy example, allowing a movie to play even when the vehicle is in motion, I think it can also do things like you are asking but I am not sure
To Programming options
