When I first saw the grab bar, I thought it was really cool. Then I started noticing that other cars had them as well.
So, how much use is this grab bar? Is this something only the passenger would use? And at what point would a passenger actually use it when getting in and out. Would it be after they planted their but in the seat?
Although a corvette can be used as a nice luxury cruiser, the grab bar comes into play when a driver explores the C7's extreme cornering, acceleration, and braking ability. The passenger now has the ability to hold on tight with both hands
Not every owner takes advantage of these capabilities but if they do the passenger certainly appreciates the grab bars.
You thought the grab bar was cool?
I guess I see it as something a passenger will either use or not use, depending on how the driver drives. It does have styling elements that you can either like or not but I don't see it as cool, as a lot of cars have them.
If it is actually meant to be functional in "highly spirited driving" do you think it can be reached while the passenger is securely strapped in with back firmly against the seat? Seems like a stretch (literally, not figuratively). But I haven't sat in the car, so I don't know the distances.
The C5 had a grab handle on the dash which was indeed hard to grab when you were strapped in. At the C6 introduction Dave Hill pointed out that the the C6 grab handle was now on the door. Strong and easy to reach (at least for your right hand). Now we finally have one for each hand and it seemed to me that they were pretty easy to reach when seated.
The C5 grab bar/handle, mounted on the instrument panel, also acted as a "diverter" to insure that the passenger side air bag deploys in the intended path (doesn't go too high). The C5 used a mid mount air bag as opposed to the upper mount air bag that most GM vehicles used during the mid to late '90s. So there was an engineering purpose to the handle, as well as a styling purpose.
If you look at some of the other GM vehicles introduced during the late '90s/early 2000s, they used a brow as a diverter/styling feature, and the GMT 800 trucks/SUVs also had a handle that acted as a "diverter".
