C7 Nomenclature and Tech Data
So do we know the nomenclature for the new 7 speed, or the new DI heads, or for any of the particular hard parts as such? Do we have gear ratios and/or spline counts for the new mainshafts? Are Z51 and base differential or transmission gears different ratios? Do we have wheel offsets yet? Etc, etc.
I'd like to begin itemizing stuff we find here for reference if anybody has anything.
Paging Talon (Paul)!
Same ratios as C6 TR6060 with added 7th OD; .42 standard/ .48 Z51.
http://forums.corvetteforum.com/1582898707-post3.html
http://www.gmhightechperformance.com..._transmission/
Haven't seen anything tech like shaft size/splines yet. Some implications they are same as C6 Z06 but can't verify.
Wheel offsets said to be same as C6 but haven't seen anything concrete. This is all I have on that:
http://forums.corvetteforum.com/1583760742-post1.html
...........................A6....Z51A6.. ...MN7...Z51MN7
First gear............... 4.03 .. 4.03 .. 2.66 .. 2.97
Second gear.............. 2.36 .. 2.36 .. 1.78 .. 2.07
Third gear............... 1.53 .. 1.53 .. 1.30 .. 1.43
Fourth gear.............. 1.15 .. 1.15 .. 1.00 .. 1.00
Fifth gear............... 0.85 .. 0.85 .. 0.74 .. 0.71
Sixth gear............... 0.67 .. 0.67 .. 0.50 .. 0.57
Seventh gear............................. 0.42 .. 0.48
Reverse.................. 3.06 .. 3.06 .. 2.90 .. 2.90
Axle ratio............... 2.56 .. 2.73 .. 3.42 .. 3.42
Overall ratios:
...........................A6....Z51A6.. ....MN7...Z51MN7
First gear...............10.32 ..11.00 .. 9.10 ..10.16
Second gear.............. 6.04 .. 6.44 .. 6.09 .. 7.08
Third gear............... 3.92 .. 4.18 .. 4.45 .. 4.89
Fourth gear.............. 2.94 .. 3.14 .. 3.42 .. 3.42
Fifth gear............... 2.18 .. 2.32 .. 2.53 .. 2.43
Sixth gear............... 1.72 .. 1.83 .. 1.71 .. 1.95
Seventh gear............................. 1.44 .. 1.64
Interior Room C7 vs C6:
C7 inches (mm):
Head room, front 37.90 (963)
Shoulder room, front 55.20 (1402)
Hip room, front 53.70 (1364)
Leg room, front 43.00 (1092)
C6 inches (mm):
Head room, front 37.70 (958)
Leg room, front 43.10 (1095)
Mass Additions/Reductions from C6:
Areas Of Mass Reduction
Frame: 99 pounds lighter
Body panels: 37 pounds lighter
Hatch: several pounds lighter
Control arms: now hollow, several pounds
Total weight savings is in the vicinity of 150 pounds, or 68 kg.
Areas of Mass Addition
35.2 pounds — direct injection, VVT, AFM
6.6 pounds — standard engine oil cooler
13.2 pounds — dual mass clutch
15.4 pounds — steel torque tube part of AFM
5.5 pounds — AFM exhaust valves
11 pounds — 7th transmission speed
18.5 pounds — strengthened differential, half shafts
18.3 pounds — larger fixed brakes
17 pounds — new interior appointments and safety features
17.2 pounds — upgraded seats
18.5 pounds — structural safety requirements
31.5 pounds — new infotainment and cabin technology, as well as relocating battery to the rear
3 pounds — bigger fuel tank
That’s a total weight gain of 210 pounds, or 95 kg
Exterior Dimensions C7 vs C6
C7 inches (mm):
Wheelbase 106.70 (2710)
Overall length 176.90 (4493)
Body width, without mirrors 73.90 (1877)
Overall height 48.80 (1240)
C6 base inches (mm):
Wheelbase 105.70 (2685)
Overall length 174.60 (4435), Z06 175.60 (4460)
Body width, without mirrors 72.60 (1844), Z06 75.90 (1928)
Overall height 49.10 (1247)
Other swap options there too, and from manuals to autos and etc (given proper BCM/etc programming and matching tailhousings for the respective cases) to suit your particular engine combo or tire size if you're drag racing.
Sweet.
Now, onto where we can start shaving....
35.2 pounds — direct injection, VVT, AFM (Some of that must stay, like the DI setup, but the current L99 cars have seen VVT/AFM deleted... wonder what the savings is there? Maybe we can shave 10lbs?)
13.2 pounds — dual mass clutch (Aftermarket clutch/aluminum flywheel could shave +/- 20lbs)
18.3 pounds — larger fixed brakes (2 piece rotors here could save 5lbs per corner, 20lbs total)
17.2 pounds — upgraded seats (I'm assuming the Competition seats would be at least 10 or 15 pounds lighter per seat? 20-30 saved perhaps?)
31.5 pounds — new infotainment and cabin technology, as well as relocating battery to the rear (If so inclined, this could nearly all be deleted, and a 12-15lb Braille battery added for a total savings of probably 50+lbs)
That’s a total weight gain of 210 pounds, or 95 kg (Could realistically remove nearly 100lbs of that).
BTW I tried one of Braille batteries and unless you drive the car daily or every other day, they need a trickle charger and don't hold their charge well over a week or two of not driving.
There will definitely be a C7 in my future. I can't say when... as you're right, I'll be immensely enjoying a certain silver C6Z.
Still, when it comes time, I'd like to have my gameplan laid out and full situational awareness as far as my options. I know the Braille batteries are a chore. The C6's already are extremely battery/voltage sensitive. We don't know how the C7's designed yet, though. Perhaps GM has figured out how to make a battery last like any other car's.Plus, this is something else to focus on while I avoid going stir-crazy waiting to fly to Texas.
