Another C7 Accident
Old Aug 3, 2013 | 09:05 AM
  #121
Turbobndt's Avatar
Turbobndt
Originally Posted by zhopper05
I still think it's a fake. If you look at the other picture posted from the rear, the "photoshop" shows dents in the Corvette. The Corvette body would break apart if hit, and not dent.
If this was a photoshop I certainly would have included my own team of accident investigators. I believe it to be real.
Old Aug 3, 2013 | 09:10 AM
  #122
gthal's Avatar
gthal
It's real unless someone went out of their way to photoshop various angles and make everything consistent
... conspiracy theorists abound
  #123
Big Dan 427's Avatar
Big Dan 427
Probably a new demographic youngster driving it that couldn't handle the hp!
Old Aug 3, 2013 | 09:26 AM
  #124
0-60B4U's Avatar
0-60B4U
Several different photos of different angles from different members have been posted on this site and you still think it is "photo-shopped"! Amazing! Guess you think the world is still flat?
Old Aug 3, 2013 | 10:54 AM
  #125
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Uh, my corvette didn't break when I got into an accident, and neither did my other plastic/SMC cars. It will dent.
Old Aug 3, 2013 | 11:11 AM
  #126
zhopper05's Avatar
zhopper05
2015 C7 of Year Finalist
I do like your sens of humor. However, let's get technical a little. Correct me if I am wrong - Unless the C7 was driving across the pedestrian crosswalk, the impact we presumed happened somewhere in the intersection, and the Lincoln must have dragged the C7 across and onto the crosswalk. If that was the case, why then, all the debris from the impact appears to be all concentrated where the cars ended up rather than at the point of impact, or possibly scattered?
Also, if you look into the side mirror of the photographer's car, do you notice that the first car shown appears to be a black damaged car? Or is it just me?
Old Aug 3, 2013 | 11:16 AM
  #127
zhopper05's Avatar
zhopper05
Over the years, I've had 3 corvettes hit, and all three times, the body surface that did not crack, bounced back into place. I'll give you the possibility of some areas may get just enough stress to bend but not enough to crack. However, while, supposedly, the C7 was dragged after the impact, don't you think you would see scuff marks on the wheels from the Lincoln's bumpers?
There are so many question marks...
Old Aug 3, 2013 | 11:19 AM
  #128
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Yes, it is just you.
Definitely a real photo.
Old Aug 3, 2013 | 11:21 AM
  #129
zhopper05's Avatar
zhopper05
I guess if it's posted on the internet then it's automatically true. Right?
Old Aug 3, 2013 | 11:24 AM
  #130
zhopper05's Avatar
zhopper05
Maybe. Like I said, I could very well be wrong. But the thing that puzzles me is the concentration of debris at the point of rest rather than point of impact or even scattered. That, I am having a hard time explaining.
Old Aug 3, 2013 | 10:57 PM
  #131
0-60B4U's Avatar
0-60B4U
As a former accident investigator for a Metro PD, I found there was almost always more debris where the vehicles finally stopped than where they first collided. Because of the debris in the street before the crosswalk, it is very obvious to me that the Vette was hit while in the intersection making a left turn. The left front corner of the Lincoln made first contact with the Vette's door near the handle. The Lincoln's impact slid the Vette straight and the Lincoln's right front corner then impacted the door near the hinges. That's why there is more damage to the door near the handle than at the hinges. It is likely that the Lincoln stopped it's forward movement before the Vette quit sliding sideways. That's the reason there is a separation of the two vehicles and why most of the debris is in between them.
Old Aug 4, 2013 | 07:41 AM
  #132
janicept's Avatar
janicept
That is so sad to see. I love the look of the blue one - just not in the grass.
Old Aug 4, 2013 | 07:17 PM
  #133
zhopper05's Avatar
zhopper05
Thanks for the clarification. But, can you please explain to me why there would be a wider debris field at the resting point, rather than point of impact? I am trying to understand it from a physics stand point. The C7 was apparently dragged/pushed a distance in excess of 40 feet. Don't you think the impact would have spun the Vette once the corner of the Lincoln reached the door handle of the Vette? Just asking. I may be dense, I am simply trying to learn....
Old Aug 6, 2013 | 08:01 AM
  #134
TXGS507's Avatar
TXGS507
EXACTLY!!! That is what the Avalanche Z71 is for...
Originally Posted by rothchilds
well duh, that's why you don't drive it in the rain!
Old Aug 6, 2013 | 09:31 AM
  #135
lt4obsesses's Avatar
lt4obsesses
Two factors:
1) Momentum. Those parts that 'exploded' off the car at impact were traveling the same speed and direction as the car, thus they followed the car to it's resting place.
2) Delay. Many parts will become patially dislodged at impact only to become fully dislodged after coming to a rest. Internal parts that did come fully dislodged at impact, will still follow the car until the resting point.
Old Aug 6, 2013 | 09:35 AM
  #136
Walt White Coupe's Avatar
Walt White Coupe
Originally Posted by lt4obsesses
Two factors:
Thank you for adding some actual understanding and knowledge about crashes and their aftermath in this ridiculous "photoshop" discussion.
Old Aug 6, 2013 | 09:52 AM
  #137
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
They can definitely crack sometimes as a friend of mine found out last week.
To Another C7 Accident
  #138
0-60B4U's Avatar
0-60B4U
Why are you trying to make this so difficult? First of all the Lincoln pushed the Vette. There was no dragging! Second, the Vette was pushed only about a car length after it was hit. Not 40 plus feet! This is very evident by where the debris starts and ends. Third, neither the Lincoln nor the Vette was traveling very fast. Probably in the neighborhood of 10-15 mph. Any faster and there would have been much more damage to both vehicles. And Fourth, to spin a vehicle around, it has to be hit hard at the very front or back corners. When a car is T-boned, it doesn't spin around, it just gets pushed straight.
Old Aug 6, 2013 | 10:34 AM
  #139
ByByBMW's Avatar
ByByBMW
Um, maybe in a perfect world. But my Tundra pickup got T-Boned almost dead center and it spun 270. To many variables to make a blanket statement like I highlighted.
Old Aug 6, 2013 | 10:43 AM
  #140
McGirk94LT1's Avatar
McGirk94LT1
Two factors:
This. Of the parts that are damaged heavily, some will explode off. The rest, loose bits will be stuck travelling at the same speed as the car. When the car comes to a stop, all the loose parts are essentially whiplashed forward.
A la a cup in a shallow cup holder when you hit the breaks... a la momentum.
