Coupe/Vert Dimensions/Spec Differences
Old Aug 5, 2013 | 12:02 PM
Zymurgy's Avatar
Zymurgy
Moderator
Default Coupe/Vert Dimensions/Spec Differences
Vert has 5 cubic feet less cargo capacity than coupe and weighs 64 pounds more than coupe. It is also 0.7 inches taller than the coupe.
Old Aug 5, 2013 | 12:41 PM
JoesC5's Avatar
JoesC5
Compare to a 1965 Convertible(the "original" Sting Ray) that had 39" of head room and 8 cu ft of usable trunk space(and not even a trunk with a lid). And was 4.3" narrower and 1.8" shorter in length then the current StingRay.
But they both held 18.5 gallons of gas.
Old Aug 5, 2013 | 01:47 PM
stevelischynsky's Avatar
stevelischynsky
The 10 cu ft of cargo on the convert is probably with the top down. With the top up, it looks like you can use the space where the top would normally collapse.
So, if you are on a long trip on freeways, you would probably keep the top up for the duration of the trip, and therefore use the extra space for luggage where the top would normally be stowed. Any one know how many cu ft that would be?
Old Aug 5, 2013 | 02:44 PM
Sin City's Avatar
Sin City
2020 C8 of the Year Finalist - Unmodified
With the top down the interior space goes to infinity.
Old Aug 5, 2013 | 02:57 PM
VETJAZZ's Avatar
VETJAZZ
Amen!
Old Aug 5, 2013 | 05:35 PM
cam30era's Avatar
cam30era
I believe that 10 cu ft is with top up.
To Coupe/Vert Dimensions/Spec Differences
