Gear Question
Old Aug 9, 2013 | 11:58 AM
luvlake's Avatar
luvlake
Default Gear Question
On the C7 order form I see a 2.73 ratio and a 2.56 ratio with the 3.42 being the standard. I intend to order a C7 Convertible Z51, I don't plan to track the car or do Top End racing. I want the best all around performance and gas mileage. What is the difference and which one should I choose?
Old Aug 9, 2013 | 12:03 PM
CaryBob's Avatar
CaryBob
That is not something you can order. They are the result of other choices.
All manual transmissions are 3.42. Automatics are either 2.46 or 2.73 depending on whether you choose the Z51 option or not. Since you are ordering Z51, you will get 3,42 if a manual, 2.73 if an automatic.
Old Aug 9, 2013 | 12:05 PM
robvuk's Avatar
robvuk
The final drive ratio will definitely improve mileage but it will be at the expense of overall performance. The meaningless 0-60 will be slower and the 1/4 mile will suffer in both top speed and E.T. However, the improvements in mileage will mostly only be realized on the highway. So if you do many road trips, it will definitely save gas. Otherwise, not so much.
Old Aug 9, 2013 | 12:07 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
If you are ordering a manual transmission car, your only choice will be a 3.42 ratio.
If you are ordering an automatic transmission with the Z51 your only choice will be 2.73.
If you are ordering an automatic transmission without the Z51 package your only choice will be the 2.56.
Old Aug 9, 2013 | 12:24 PM
Shaka's Avatar
Shaka
Correct. A lot of guys run 4:11 gears in their Vettes but often switch back to 3:42 because they have to use the over drive gears which requires more gear changes, taller overall ratios and slower lap times. The higher the ratio, the higher the temperatures also. Tire wear increases as do carrier clutches. The properties of the rear axle are second only to tires for performance.
Old Aug 9, 2013 | 12:28 PM
robvuk's Avatar
robvuk
And yes. There really is no choice. You get the package one way or the other. So there is no comparing the mileage you get with the 2.73 vs. the 3.42 with a manual tranny.
Old Aug 9, 2013 | 12:30 PM
robvuk's Avatar
robvuk
I guess my post more accurately described a scenario where the user changes the final drive ratio to a 4.11 or other choice. Which brings up the question about the eDif. Talon90 may know the answer, does the eDif make changing gear ratios all but impossible?
Old Aug 9, 2013 | 02:27 PM
Shaka's Avatar
Shaka
I doubt it.
Old Aug 9, 2013 | 03:32 PM
Mike Mercury's Avatar
Mike Mercury
I'd imagine it would complicate the reprog process, it's more than WOT shift points this time (automatic tranny).
Old Aug 9, 2013 | 04:26 PM
Shaka's Avatar
Shaka
I don't know if the diff has an isolated ECM or if it gets inputs from other systems, such as active handling, steering in put, braking input, accelerometers, etc.
If it only gets torque and traction signals, I don't think it would have to be reprogrammed with a pinion and crown wheel change. I would like to see a lot of tech data released on the C7 such as this but anything electronic is usually closely guarded. I think it is simply active locally unlike f1 and rally cars. I wonder if a F458 or a GT3 ediff gets info from its DCT?
To Gear Question
