Oh, sure, I like the show, but Clarkson seems to think that Europe is a country when he's talking about cars.
What I really watch it for is the list of lap times and how various cars stack up, although track conditions vary so much you can't put too much on it.
Really? So if the computer decides the engine is not hot enough, it could cut fuel at 3,500RPMs or some other calculated number?
Sounds like an inconvenience to me.
I would recommend looking at the file. I don't remember the triggers off hand, It is something like if the temperature is below freezing and the oil temp is below 100 then RPM is limited to say 4000. While you may call that inconvenient, it saves your engine from the most damaging actions a driver can take. It helps protect GM from paying warrantee claims for drivers doing really stupid things.
Correction: I went to the file and checked. The actual parameters are: coolant temperature and engine run time. They cutoff RPM varies by temperature and time.
Reason: Correction
Makes sense when you put it that way. I wasn't thinking of freezing temps and extreme conditions.
I'll be waiting for Clarkson's obligatory comments about the transverse leaf springs right off of a stage coach.
Dave
They already got rid of the wooden floor boards. I'll be really pissed if they mess with the leaf springs and the push rods.
Did the stage coach have push rods?
I thought the tachometer just showed a lower red line when the engine is cold?????
Can you point me to a link where it discussed actual fuel cut off at a lower RPM when cold/etc.
Download the program. Go to your my Documents>HP Tuners>Logs and Tunes>Samples and select the 2014 Corvette file. When it opens instead of putting in an activation code use Demo mode.
Go to Engine> Fuel> Cutoff, DFCO it has a Startup Modifiers section, click on Cold Engine and it has parameters.
Look at that an tell me your interpretation of what is there.
I am sure you have to be in the Advanced mode to see all the parameters.
It looks at the coolant temperature and Engine run time. not oil temp as I said previously. So at -40f and run time up to 60 seconds the fuel cutoff is 4600 RPM. Different temperatures cause different delays, and cutoff RPMs before full RPM is available.
Thanks for the info. I had NO idea the engine was set up to do this.
Why must you keep antagonizing those poor "Sixers"? You know they are gonna come in here and pick more nits...ranting about taillights and such.
What can I say. I'm tired of seeing the same people crapping on the car and not moving on with their lives, and instead trying to make things so negative here in the C7 section.
I'm really looking forward to Clarkson driving this. Too bad it probably won't be for several more months as TG isn't back until the winter.
You don't need Clarkson driving it, the car can almost drive itself! I'm waiting for the C8 where no driver will be needed. Think of the possibilities...watch the big game while you (it) goes for a drive!
My M3 and M5 also did this when the engine was cold. It only lasted a few minutes and by the time I was out of my neighborhood it was "warm enough" where the RPM's were back up to normal.
See above for when someone has nothing meaningful to complain about
Electronics can be turned off for bench racers wanting to feel cool or for the pros who actually know what they are doing.
What the Brits love is hanging out the tail and lots of tire smoke. The reviewers generally love manual boxes and good creature comfort/controls.
I think the looks are really "American" and that will be a knock, as well as the black grills and targa looking out of the 80's. But, in general, I think they will like it for what it does and love it's price.
My 2004 E46 M3 lowers the yellow/red rpm range on the rpm indicator when it is cold, and moves up as the oil warms, but it does not change the limiter (fuel cut-off) from its normal value as what is being suggested the C7 does in this discussion. That would be a nice feature to help protect the engine if true.
They must have driven it (someone) given the comments they make. You couldn't make comments about front/rear grip, etc otherwise.
Yes, this part seemed particularly conspicuous to me as in they've driven it.
There's stacks of grip at both ends, the adjustable steering communicates really well when you want it to and fades away when you don't, the chassis absorbs changes of input from the road and driver without issue. And, best of all, it's all massively entertaining in the process. Unlike a lot of high performance cars which don't give you much feedback until the limit, you really feel like you can thrash the C7 and get all the value out of it at all speeds.
So should I buy one then? If you've ever thought about a 'Vette, now is the time. By thoroughly updating the car the C7 team have vaulted to the front of the wave of modern two-seater sportscars. There really isn't anything else on the market that does as much as this car can do for even twice the price.
Car still keeps getting positive reviews....
I have to drive one .... especially the auto.
But in the end I believe it's all just a setup for the big fail on the show.
And, that makes for good car show entertainment.
That C7 article was written by TopGear's L.A. editor, Pat Devereux. Bear in mind that British roads are often quite different from those chosen by manufacturers for media events in America, though I think the improvements to the C7's handling and suspension should reap benefits for the Brits. As for style, the TG television presenters generally don't have a problem with the style of American cars. Clarkson lusted after the Ford GT and Hammond is a big-time musclecar fan (owns a classic Mustang and Charger, last I heard).
Who in their right mind is going to rev the engine to above 4600 RPM (let alone way below that) when the coolant temperature is -40 F? I mean, I can picture it now ... go outside when it's -40 deg F, fire it up and smash the throttle to the floor. Any idiot that does that shouldn't own any motorized vehicle, let along a Vette.
