Rotor Cooling Rings
Old Sep 23, 2013 | 09:42 PM
RapidC84B's Avatar
RapidC84B
Been tracking/racing C5s for a decade. Don't really see the need for these things. I would just fit my car with spindle ducts and brake cooling ducts to direct fresh air to the center of the rotor. The rotor is an air pump already... give it fresh air and it'll do what it needs to do. Many of us have raced on the old stock C5 slide rail calipers with success. The OEM bits on the C7 are light years ahead of that stuff and far better than the outgoing C6 Z06 bits.
Old Sep 23, 2013 | 10:01 PM
RxCritical's Avatar
RxCritical
Cruise-In X Veteran
Originally Posted by talon90
Rotor cooling rings will ship with the Z51 equipped cars for track use.
Mine didn't have them
Dealer is checking into it.
Old Sep 23, 2013 | 11:19 PM
Trackaholic's Avatar
Trackaholic
Originally Posted by Snorman
I would recommend running without them to determine if they are necessary. Some tracks are much harder on brakes than others and they may or may not be needed.
S.
One of the tracks I frequent is Laguna Seca, which is known to be tough on brakes. Still, I like your suggestion, and would likely follow it.
Also, depending on how badly these corrode, I might be able to keep them installed all the time as the weather in CA tends to be pretty easy on metals from a corrosion standpoint.
-T
Old Sep 23, 2013 | 11:29 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
-T
The corrosion issue has my interest as well. I probably won't put them on the car and will see how it does. I'm considering slipping it in to a 3-day event I'm doing with the Ohio Audi guys at the Daytona Rolex course in December for which I'm already registered with in another car.
S.
Old Sep 25, 2013 | 04:40 PM
sd7ss's Avatar
sd7ss
(This is a recent note to dealers regarding the cooling rings)
Click on the attachment; NOT "click to open full size"
File Type: pdf
Old Sep 26, 2013 | 08:16 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hi Rx,
How is this going? Did the dealer find anything out? I would like to help too! Please PM me with your VIN and name of the dealer. Thanks,
Kelly J.
Chevrolet Customer Care
Old Sep 26, 2013 | 08:28 AM
John_R's Avatar
John_R
Originally Posted by The Clevite Kid
Paul, is there anything that you DON'T know ?
Who needs Wiki or Google, when you got Paul here
Old Sep 26, 2013 | 11:09 AM
dgerstel's Avatar
dgerstel
Looks to me like the rings block the air slots that are there on 2 piece rotors and go through the disc assembly from inside to outside. This will force the air coming from the air ducts thorough the internal disc vents that go through the disc itself.
Dale
2013 Camaro ZL1
2014 Corvette @4B00
Old Sep 26, 2013 | 07:02 PM
dgerstel's Avatar
dgerstel
Had more time, so to clarify last my post.
One piece brake rotor. Air from brake air duct and from centrifugal force flows through the vents in the disc rotor, cooling the rotor.
Two-piece brake rotor used on C7. If the gaps between the brake hub and rotor are not sealed, the air from the brake air ducts can just pass thru and will not be forced thru the vanes in the rotor.
Dale
2013 Camaro ZL1
2014 Corvette @4B00
