Launch control
Old Sep 29, 2013 | 11:35 PM
darkhorsevette's Avatar
darkhorsevette
Default Launch control
I know all the c7 are new and still in the break in stage, but has anyone used the launch control, and also does it void any warranty if used....my brother has a Nissan GTR and if he use the launch control it automatic void the warranty... Back to the c7, some of the reviews had problems with the launch control.....so many reviews turned it off....
Old Sep 30, 2013 | 12:55 AM
Bill Dearborn's Avatar
Bill Dearborn
When GM announced launch control back in 2010 they specifically pointed they wouldn't void warranties like Nissan was doing. I believe Nissan has fallen on their sword and is not doing that anymore. It was a stupid policy.
Bill
Old Sep 30, 2013 | 03:44 AM
KingMotley's Avatar
KingMotley
St. Jude Donor '14
Whoa? Why would using launch control void the warranty?
Old Sep 30, 2013 | 08:22 AM
darkhorsevette
It's kinda like admitting to racing, because why would you use launch control if you wasn't racing.....gtr owners was blowing out tranny ,so Nissan stated that once launch control was activated one time , the warranty on the car was voided ( to use it you have to go through a sequence like you was a astronaut)....but lucky Chevy doesn't void their warranty by using it..
Old Sep 30, 2013 | 09:09 AM
Baron7700's Avatar
Baron7700
I used it once. I just wanted to try it, and once I got moving I left off the throttle to about 50-60% and rolled out. It works as designed.
Old Sep 30, 2013 | 10:18 AM
DracoDan's Avatar
DracoDan
Yeah, Nissan had that policy, until they had their a__ sued for it! It only applied to MY 2009 cars, starting in MY 2010 Launch control was a supported feature but will lock out if used more than 3 times in a set period of time.
As for the corvette
Yes, we're admitting to racing a race car, that's what the corvette is. If GM started punishing people for racing their race car, they would be in the same boat Nissan was in when they tried to void warranties on the GTR, not to mention the backlash from the community.
Old Sep 30, 2013 | 03:46 PM
darkhorsevette
As for the corvette
Old Sep 30, 2013 | 03:48 PM
Kappa's Avatar
Kappa
Nobody had problems with the launch control and its not something you turn off. Many drivers are faster without it and decide not to use it.
Reading comprehension is your friend.
Old Sep 30, 2013 | 03:49 PM
Starman's Avatar
Starman
Can someone explain Launch Control.
IS it simular to what is used in drag racing, called Line Lock.
Line Lock is button on the shifter which, when pushed while stopped, allows your front brakes to lock while allowing you to spin your rear tire and disengages, Allows you to get off the line faster.
Old Sep 30, 2013 | 03:54 PM
darkhorsevette
its Probably The Best Thing For Rear Wheel Drive, Helps With The Side Spin....Too Many Inexperience Divers Out There....Thank For Your Info...
Old Sep 30, 2013 | 03:58 PM
Kappa's Avatar
Kappa
No its not.
In the Corvette application, it used for people who want to get off the line consistently time after time that may not be the best at controlling wheelspin.
Here's a video.
To Launch control
