2LT Kalahari interior code question
Old Sep 30, 2013 | 07:23 PM
trivette's Avatar
trivette
Default 2LT Kalahari interior code question
My car has been built (#307) and I'm still waiting for delivery from the Nashville QC deal. In the meantime I ordered a copy of my build sheet from the NCM and it arrived today. My exterior color, Torch Red appears as GKZ as expected but under interior color it shows Black 341. My order clearly indicated Kalahari which shows up as 345 on the current order guide that I've seen for a 2LT but is indicated as 343 on the guide available when the car was actually ordered. Does that indicate black for the basic interior and only the trim accents and seats would be other than black? If so where does the Kalahari reference show up? Perhaps they changed some of the codes prior to actual production, but now I'm beginning to wonder what I'm getting?
Old Sep 30, 2013 | 07:35 PM
trivette's Avatar
trivette
My bad...actually has been 343 the entire time-I looked at 3LT by mistake. The question still remains, however, as the 341 interior color on the build sheet just says black and I don't find 341 on the order guide at all.
Old Sep 30, 2013 | 07:44 PM
Ken Fichtner's Avatar
Ken Fichtner
Cruise-in I Veteran
Cruise-in II Veteran
Cruise-In III Veteran
341 is not an option code. It may appear on the build sheet as it reflects the code used by the plant on the build sheet. The build codes sometime differ from "order" codes. 343 is the correct order code for Kalahari perforated Mulan leather seats.
Old Sep 30, 2013 | 07:47 PM
RicK T's Avatar
RicK T
No 341 code.
Can you type the exact text you are looking at, the whole line(s)?
Old Sep 30, 2013 | 08:55 PM
Zymurgy's Avatar
Zymurgy
Moderator
Here are the interior trim codes:
Old Sep 30, 2013 | 09:01 PM
trivette's Avatar
trivette
On the build sheet headed OPTION CONTENT it says:
Exterior Color: Interior Color: Headlamp Color: Caliper Color:
GKZ TORCH RED 341 BLK 8366 J6F RED
I didn't find 341 listed on the order guide either, but showed 343. If I am getting Kalahari how can you tell by the build sheet?
It also references Seats:
335 038 which I interpret as being the type, not
the color.
My '05 is black with red interior and that is clearly shown on the build sheet, which is why I'm confused on this one.
Old Sep 30, 2013 | 09:09 PM
RicK T's Avatar
RicK T
Could the "Blk" be associated with the "Headlamp Color"?
In any event, you know you're getting Khalahari because of the (34* ) code. All of the Khalahari codes start with "34". Black all start with "19". Can't explain the 341 but there's probably a lot we still have to learn.
Old Sep 30, 2013 | 09:15 PM
frciavet's Avatar
frciavet
Mine is a 3LT and reads 345. Vin is 2083.
Fred
Old Sep 30, 2013 | 09:23 PM
trivette's Avatar
trivette
The headlamp color is listed as 8366. (When I typed the line it reflowed and made it confusing to read.)
Maybe the 34 (Kalahari) and the 1 from the 19 of black is what the 341 code means-that would be logical. I hope that's the case.
To 2LT Kalahari interior code question
