Does anyone know how to change the display on the gauge cluster? I have seen pictures of track mode but cannot get my car to change to it. According to manual it goes by drive mode but when I switch to track or sport the gauge cluster stays the same. It mentions something about having it linked but I cannot figure out how to do it.. Any input appreciated!!!
The car should have been set to default in touring mode with the IP set to tied to drive mode selector. If not, it is easy to get back there.
Using the right arrow on the four way switch on the steering wheel it will bring up a menu for Driver Mode Theme and the choices are "Link to Diver Mode". Setting it here should bring up the Track IP when you set it to Track.
You can also choose between Tour, Sport and Track as the default theme.
Right arrow to bring up the menu. Up and down arrow to scroll to your choice and select to choose.
Hey Talon...not sure if this is happening all the time. Mine was not set to "tied to driver mode select" when I picked it up. Unless someone at the dealer changed it prior to me taking the delivery?
Use the up and down arrow to scroll through the choices and use the SEL button to choose. Pressing the Link to Driver mode will set it so that when you move the driver mode selector from tour to sport to track it will change the IP display to the default gauge set for that driver mode.
