i have read a few reviews from C7 owners that the blindspots are bad on this vehicle at 4 o'clock and 8 o'cklock. Specifcially when backing up, which i thought the camera would help out on, but have read that the camera just points down at the ground and does not provide much help. I am looking at buying my first vette and wondered if the C6 was just as bad? And, does this cause concern for anybody in buying one? Is this kind of typical in most high end sports car? i have test driven a new camaro and they are known for their bad blindspots. Just curious what you, more experienced, corvette owners have to say.
The camera does not "just point down at the ground". It works as well as any I've had in my cars (maybe except for my wife's QX56 with that fancy all-around "Camera" view).
S.
I'm a believer in proper adjustment of mirrors eliminates blind spots. Most people have them looking too parallel to the side of the car. I have not had the good fortune to drive a C7 yet (mine is being held up by Z51 and C2Z constraints), so I cannot verify that proper adjustment will solve the problem. However, I have driven a number of vehicles with severe blind spots and I could always eliminate them by adjusting the side mirrors.
I'm not even the slightest bit concerned about this (and my C7 will be a daily driver).
I had a C6 and was use to being able to look back. Can't do that anymore. For me it is just adjusting to not being able to do what I could before. It's pretty much all mirrors. My brother drove my C7 back from the museum and he had just sold his new Camaro SS because of the bad blindspot. He said he had no issues at all.
My c6 had bigger back windows, the c7 back window is very small and you have to be careful with the blind spot.....but after driving the c7 I learned to adapt....my rear view mirror are directed out more...bottom line is any new car , doesn't matter if it's a corvette or civic you have to adjust...with me in the c7 it was adjusting the rear mirror out more then usually I do with my other cars.....
And the the backup camera solves the real blind spot and that is directly behind you and below the line of sight.
Blind spots? Adjust your mirrors properly. How in the world can those hundreds of thousands panel trucks/van with no windows etc drive around the busy, congested streets.
I am working on having the drivers side mirror made with a convex glass - like all European mirrors - to eliminate the blind spot on the driver's side. Once I have my first 12 made I will offer them for sale somehow. I now drive all my cars with the convex mirror and love it. Wish DOT would approve so that the US manufacturers could install them from the factory.
Not an excuse for a poor design. It is a sports car, visibility all around matters.
Really? Please name the closed sports cars (coupe or roadster with the top up) you have driven that offered uninterrupted visibility all around. I'm not trying to argue, but examples will be few.
I realize some cars may be better than others, but unless you use the three mirrors mounted on any car (sports car or otherwise) you will have blind spots.
Visibility out the rear quarters is terrible in my C6 convertible when the top is up. You just learn to use your mirrors and get used to it. Doesn't bother me at all now. I wouldn't be too concerned about the C7.
On the other hand, if you buy a convertible your rear visibility will be excellent when the top is down!
At first, I found the blind spots disconcerting. However, after about 500miles, they are no longer a problem. Taking time to adjust the mirrors for maximum effect makes a big difference. Also, I find that, when in doubt, I am able to look over my shoulder for issues. To the right, the passenger side quarter window does offer a limited, but useful, view. To the left, I just lean forward slightly before looking over my shoulder. Seems to work for me.
All that having been said, I am very interested in the convex mirror idea as described by Volvos80 above.
I just received the normal drivers side mirror and the auto-dimming mirror from my local Chevy dealer. The auto dimming is made up of 2 levels of glass and an electrical connector which changes the liquid in between the 2 glasses to dim the mirror. It is a bit thicker, but my convex glass will work in both designs, but will not be auto-dimming due to the excessive cost. It is 5 times more expensive. I should have convex mirrors made in a few weeks.
Most drivers incorrectly set their outside rearview mirrors. They adjust them to see a sliver of each side of the car body from driving position.
The correct way is to set driver's mirror just beyond seeing body and to lean 45 degrees toward passenger side and set that mirror to just barely see the body
Of course, you should still look over the shoulder before crossing the lane line and your mileage will vary depending on each cars height, window frame shape / pillar configuration and rear view mirror size.
I learned yesterday that with today's cars you have to clear the area visually before backing, even if you are proficient with mirrors. Hit a small black sign pole backing, saw it about a 1/2 second before hitting. Lesson learned to the tune of $500. Car in the body shop today.
