Door to Rocker Alignment
Old Oct 8, 2013 | 07:14 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Door to Rocker Alignment
I noticed this past weekend that the bottom edge of the door is inset from the edge of the rocker panel. Does anyone know why they did that design?
Old Oct 8, 2013 | 07:38 PM
Bill B 1's Avatar
Bill B 1
Don't know but I understand it is intentional. Probably has to do with clearance when opening/closing due to the outer panel design. Just a guess.
Old Oct 8, 2013 | 07:45 PM
JoesC5's Avatar
JoesC5
Probably because crap thrown up from the front tires were chipping the bottom of the doors, so they recessed them slightly.
Old Oct 8, 2013 | 08:56 PM
MThomas's Avatar
MThomas
I asked the same question while on my buyers tour. Was advised it was done to help eliminate air flow going into the opening which would cause wind noise. I can see it.
Old Oct 8, 2013 | 09:16 PM
Greg00Coupe's Avatar
Greg00Coupe
I don't know but it sure is uniform..... must be intention but looks weird. No one will ever notice it except us pickers!!
Old Oct 8, 2013 | 09:21 PM
michaelinmech's Avatar
michaelinmech
Do you read me . . . .
This is Ground Control to Major Tom
There's nothing wrong
Old Oct 9, 2013 | 09:48 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Man get a grip on yourself. I never said there was anything wrong with this, I simply asked the question if anyone knew why it was designed like this.
I don't understand why some members on the C7 forum get so upset at a post that are not sugar and spice on the C7. I realize there are some post that are here to try and get people going, bua agai, mine was just asking a question.
By the way, I happen to be a big fan of the C7 and that includes the rear end and I have owned Corvette's on and of (on more the off) since 1968.
Old Oct 9, 2013 | 10:13 AM
sprtplt's Avatar
sprtplt
The C7 apologists are amazing. I do not remember this being the case when the C6 came out, rather, I remember the forum community being wary and more of a "show me" attitude. And this is correct given the GM history. Maybe there are more here now who have little to no history dealing with GM?
Old Oct 9, 2013 | 10:15 AM
travisnd's Avatar
travisnd
I noticed it. It's uniform and symmetrical on each side; appears intentional. The reason posted above seems logical.
Old Oct 9, 2013 | 10:19 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
This image is from a bulliten that was provided to all Stingray selling dealers.
Old Oct 9, 2013 | 10:28 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Thanks Talon. I knew it was on all the C7's, I happened to notice it and also a friend of mine that was also at the show mentioned and we were talking about it. The friend is extremely knowledgeable about Corvette's and he was also wondering the samething. He has written books on the Corvette Racing program and one is even available through the museum store.
Old Oct 9, 2013 | 10:30 AM
Greg00Coupe
Well I'd add............ to me from my backyard mechanic experience there is no way to adjust it out. It is what it is by ready........design...... Curious to know why but not worried or concerned.
Old Oct 9, 2013 | 01:44 PM
michaelinmech
^ ummmmmm . . . my post was humor - put a spin on some lyrics from a famous David Bowie song, to let you know it is all good - there is nothing wrong - you can have peace of mind.
Perhaps you might realize that folks may just be on your side and are being supportive rather than thinking you are somehow under fire for your Thread.
Have a Coke and a Smile . . . . . .
Old Oct 9, 2013 | 02:04 PM
Dusty Starbucks's Avatar
Dusty Starbucks
"Desing feature", that's good! Looks like an oh **** afterthought to me. If it was a design "feature" the crease would at least line up. Every car and every picture I have seen the door looks like it was put in cockeyed and the molding line is slightly off.
Old Oct 9, 2013 | 02:07 PM
michaelinmech
Cockeyed doors are the latest and hottest "Desing Feature" . . . .
Old Jul 19, 2014 | 06:18 PM
barduch's Avatar
barduch
I am late to the party as I just noticed this at the Black Hills Corvette Classic kickoff this past Tuesday. Just my opinion but I think that explanation is questionable. I looked at numerous C7s that were in attendance and some looked better than others with some even looking almost flush on the passenger side and with the big offset on the driver's side. The conundrum is that if they fix it next year they will be admitting a major mistake in year 1 of the C7. Collectors take note, it may be like the upside down airplane airmail stamp in a hundred years.
Old Jul 19, 2014 | 10:38 PM
b4i4getit's Avatar
b4i4getit
Could be just a mistake where some mold maker for the door skins was off by 13 mm. Too costly to fix now so GM just says it is "by design". You never really know with these big companies.
Old Jul 19, 2014 | 11:42 PM
ACS Composite's Avatar
0ACS Composite
Former Vendor
I have also noticed a fender to rocker difference.... I have installed my share or of side rockers and have seen this gab to be very inconsistent from side to side and especially from car to car.
The fix is fairly simply. I now pre adjust this area before installing side rockers. Simply loosen the lower portion of the fender and retighten.
You will be able to get a perfect door / fender, and fender / rocker fitment. Consequently our rockers will also fit perfectly, and they were designed using GM data, re-assuring the fender to rocker should be flush.
To Door to Rocker Alignment
