NPP variable exhaust question?
Popular Reply
The exhaust tailpipe flow control system is used to tune the exhaust note for high performance vehicles. This vehicle is equipped with two tailpipe exhaust valves. One in the left tailpipe and one in the right tailpipe. Each exhaust tailpipe valve is installed in the low restriction exhaust path of a dual outlet muffler, near the exhaust tip.
When a tailpipe exhaust valve is open, the low restriction exhaust path is opened to the atmosphere, and the exhaust note becomes more aggressive.
An output circuit from the chassis control module is used to control the actuator that opens the left and right exhaust tailpipe valves. The exhaust flow control valve opens and closes when the chassis control module commands the actuator by pulse width modulation of the control signal.
To provide a more aggressive exhaust note when the vehicle is started, the exhaust tailpipe valves are opened during an engine crank event during specific modes of operation if that option is available. Once the engine is running, accelerator pedal position, transmission gear and engine speed are used to determine the commanded state (open or closed) of the exhaust tailpipe valves.
There are four specific exhaust performance modes that result in different behavior of the exhaust tailpipe valves. These modes are:
• Weather/Eco Mode: Exhaust tailpipe valves will be closed at all times when the engine is running.
• Tour Mode: Exhaust tailpipe valves are closed when the engine is idling and during normal/non-aggressive driving. Valves open during aggressive driving.
• Sport Mode: Exhaust tailpipe valves are open when the engine is idling and during most driving scenarios.
• Track Mode: Exhaust tailpipe valves are open at all times.
It is possible to personalize the exhaust sound. Select the Driving Mode menu and the following will be displayed:
• Exhaust
• Steering
Select Exhaust. This controls how robust or quiet the engine will sound. Select:
• Auto
• Stealth
• City
• Tour
• Sport
• Track
• Off
When the engine sound enhancement is turned Off via the personalization menu, the exhaust tailpipe valves will be put into track mode no matter which vehicle mode (Weather/Eco, Tour, Sport, or Track) is displayed on the drivers instrument panel.
• Exhaust
• Steering
• Auto
• Stealth
• City
• Tour
• Sport
• Track
• Off
• Exhaust
• Steering
• Auto
• Stealth
• City
• Tour
• Sport
• Track
• Off
Anyone know for sure?
Okay to speculate and opine but would like a definitive answer if possible.
We currently offer the Fusion for C5 and C6. It replaces the OE mufflers and completely integrates with the stock NPP system - just hook up the stock vacuum lines to the Fusion.
In case folks are saying "C5 didn't come with NPP" - we have a retrofit kit. We have a retrofit kit for C6 as well.
This photo is of the Fusion for C6:
Jon, does Billy Boat have any plans of releasing a variable exhaust retrofit to C7s that did not come with NPP?
The NPP exhaust has larger exhaust tips with valves in the outer ones.
To Check:
Go to Settings (gear icon) -> Driving Mode -> Engine Sound Management
If Engine Sound Management (ESM) exists as an option, you have NPP. Then you will have settings:
2014: Auto or Off
2015+: Stealth, Auto, Touring, Sport, Track
Off and Track ESM settings are equivalent. This keeps the NPP exhaust valves open as much as federal pass-by noise laws allow. So they will still close at times.
The whole fuse pull thing mentioned is for NPP equipped cars. This fuse #41 for 2014 and fuse #42 in 2015+ cars in the engine bay fuse box. Pulling this fuse prevents the NPP valves from ever closing, but it also disables controlling their functions from the ESM settings. This is why some have rigged up a switch (wired or wireless) to control the fuse.
