Exhaust
Old Oct 13, 2013 | 09:29 PM
whitec7's Avatar
whitec7
Default Exhaust
Can you turn on and off the performance exhaust? Thank you
Old Oct 13, 2013 | 09:34 PM
C7 101 car's Avatar
C7 101 car
There are just TWO options....#1 is AUTO (factory setting) Changes with the drive mode that you are in.
#2 is OFF which is LOUD in ALL modes.
That is it NO other options !
Old Oct 13, 2013 | 09:59 PM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
question...
when in touring, sport, track
is there 3 different sounds?
Or is sport/track basically the same sounding?
Old Oct 13, 2013 | 10:07 PM
doug doo wop's Avatar
doug doo wop
How loud? Do they sound as good as aftermarket exhaust, especially at idle?
Old Oct 13, 2013 | 10:27 PM
rixvette's Avatar
rixvette
I had a Corsa exhaust on my C6. I like the performance exhaust sound and also the option to change it when I need to.
Old Oct 13, 2013 | 10:53 PM
C7 101 car's Avatar
C7 101 car
They sound as good as any aftermarket exhaust IMO
Just loud enough, but not like if you had no muffler at all.
Old Oct 13, 2013 | 11:09 PM
Michael A's Avatar
Michael A
I wish there was another option OFF (or NIGHT mode ), for driving through residential area canyons at night. There's no use getting everyone riled up just because someone wants to go fast in a C7.
Michael
Old Oct 13, 2013 | 11:25 PM
mjw930's Avatar
mjw930
Michael
There is, it's called stealth mode. There are number of modes which can be set within each driving mode so you have a lot of flexibility.
Directly from GM literature
Exhaust Tailpipe Flow Control Valve System — RPO NPP:
 The exhaust tailpipe flow control system is used to tune the exhaust note for high performance vehicles. This vehicle is equipped with two tailpipe exhaust valves. One in the left tailpipe and one in the right tailpipe. Each exhaust tailpipe valve is installed in the low restriction exhaust path of a dual outlet muffler, near the exhaust tip.
When a tailpipe exhaust valve is open, the low restriction exhaust path is opened to the atmosphere, and the exhaust note becomes more aggressive.
An output circuit from the chassis control module is used to control the actuator that opens the left and right exhaust tailpipe valves. The exhaust flow control valve opens and closes when the chassis control module commands the actuator by pulse width modulation of the control signal.
To provide a more aggressive exhaust note when the vehicle is started, the exhaust tailpipe valves are opened during an engine crank event during specific modes of operation if that option is available. Once the engine is running, accelerator pedal position, transmission gear and engine speed are used to determine the commanded state (open or closed) of the exhaust tailpipe valves.
There are four specific exhaust performance modes that result in different behavior of the exhaust tailpipe valves. These modes are:
• Weather/Eco Mode: Exhaust tailpipe valves will be closed at all times when the engine is running.
• Tour Mode: Exhaust tailpipe valves are closed when the engine is idling and during normal/non-aggressive driving. Valves open during aggressive driving.
• Sport Mode: Exhaust tailpipe valves are open when the engine is idling and during most driving scenarios.
• Track Mode: Exhaust tailpipe valves are open at all times.
It is possible to personalize the exhaust sound. Select the Driving Mode menu and the following will be displayed:
• Exhaust
• Steering
Select Exhaust. This controls how robust or quiet the engine will sound. Select:
• Auto
• Stealth
• City
• Tour
• Sport
• Track
• Off
When the engine sound enhancement is turned Off via the personalization menu, the exhaust tailpipe valves will be put into track mode no matter which vehicle mode (Weather/Eco, Tour, Sport, or Track) is displayed on the drivers instrument panel.
Old Oct 13, 2013 | 11:35 PM
C7 101 car's Avatar
C7 101 car
That is OLD literature, that can not be done. They changed it.
There are NOW just TWO options....#1 is AUTO (factory setting) Changes with the drive mode that you are in.
You could drive in Weather/Eco Mode: Which is the quietest.
Old Oct 13, 2013 | 11:56 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
If you get the Mild-to-Wild mod, you can control when it is always open with a remote control switch.
That way you can have it always open if you want it loud or revert to the RPM controlling it (Mild mode - only opens at 3500 RPM).
In mild mode you can drive conservatively through the neighborhood at night and no one will notice you.
Old Oct 14, 2013 | 12:16 AM
Dameian's Avatar
Dameian
Lol @ him ^^^^^
Old Oct 14, 2013 | 08:29 AM
whitec7's Avatar
whitec7
Where can you buy the mild to wild? Thanks
Old Oct 14, 2013 | 09:06 AM
lastcowboy's Avatar
lastcowboy
Old Oct 14, 2013 | 09:07 AM
ufaj26's Avatar
ufaj26
I'm not certain a mild to wild set up as we know it will work. My manual shows 2 fuses, number 32 and number 42 marked exhaust valve 1 and exhaust valve 2. Assuming these control the valves in the pipes.
lastcowboy's Avatar
lastcowboy
billy b. ask for mark
Old Oct 14, 2013 | 09:08 AM
ufaj26's Avatar
ufaj26
Originally Posted by lastcowboy
Wished I had ordered that button.
Old Oct 14, 2013 | 09:13 AM
whitec7's Avatar
whitec7
Can this be ordered from the factory?
To Exhaust
Old Oct 14, 2013 | 09:15 AM
ufaj26's Avatar
ufaj26
No we're kidding.
Old Oct 14, 2013 | 09:22 AM
pittperson's Avatar
pittperson
It depends on what you consider good/loud. I had BB Bullets on my C6 and those were LOUD. The stock NPP is whisper quite compared to the Bullets.
Old Oct 14, 2013 | 09:23 AM
whitec7's Avatar
whitec7
didn't think that was a option.
