Cargo Management?
Old Oct 26, 2013 | 03:01 AM
-CM-'s Avatar
-CM-
Originally Posted by Periokid
Looking forward to seeing it!
I am, also. The addition of the two tie-down eyelets in the C7 should be taken advantage of.
Old Oct 26, 2013 | 09:35 AM
Litumup411's Avatar
Litumup411
Here is something that I put together with a little bit of scrap wood that I had laying around in our basement.
It's very lightweight, weighs less than a pound, and I was able to make it specifically for my needs.
I think anyone could do it, just go to Home Depot or Lowe's and have them cut the pieces based on your measurements. It is about 3 inches tall, so that it fits flush with the bump up behind the seats. It is not reconfigurable, but it is very simple to make and inexpensive.
Old Oct 26, 2013 | 10:21 AM
JoesC5's Avatar
JoesC5
This is how, in my C6, I control a jack, a extendable lug wrench, a torque wrench with a 19mm socket and short extension , a 4'X6' plastic tarp, jacking pucks, old towel and hand cleaner. All in a 6" X 8" X 18" duffel bag, secured to the attachment points GM furnished for the cargo net.
Old Oct 26, 2013 | 10:34 AM
Mike O'Daniel's Avatar
Mike O'Daniel
Buy some of the little plastic basket carriers, shoebox size or a little bigger and stick some Velcro on the bottom.
Old Oct 26, 2013 | 02:24 PM
SCM_Crash's Avatar
SCM_Crash
I have a light C7 jacket that sits in the cargo net in the trunk. Works well.
Old Sep 17, 2020 | 01:52 PM
Vette E Boop's Avatar
Vette E Boop
I have a WeatherTech cargo mat and use an expandable/collapsible organizer to hold small stuff.
Old Sep 17, 2020 | 02:10 PM
vetteright's Avatar
vetteright
You do realize that this thread is from 7 year old posts?
Old Sep 17, 2020 | 02:44 PM
Vette E Boop
Uh-oh. No, I did not. My bad. However, it was listed on page one. I certainly did not search for this.
Old Sep 17, 2020 | 02:46 PM
vetteright's Avatar
vetteright
No biggie, just wonderin.
Old Sep 17, 2020 | 03:06 PM
Vette E Boop
Thanks for calling to my attention. I figured out what happened: I fell victim to the “Related Thread” gremlin and paged down too far to reply to current cargo thread.
Old Sep 17, 2020 | 04:48 PM
wgood's Avatar
wgood
Just get a 20.00 yoga mat and cut it to desired shape !!!
Old Sep 17, 2020 | 08:42 PM
Avanti's Avatar
Avanti
I don't know if it could be installed tightly enough in our cars, but my wife has an extendable rod in the trunk of her sedan that can be fitted to almost any width and tightened against the sides of the "trunk." Not a foolproof solution, but it works remarkably well in her application and gives a very solid restraining rod that can be moved about as needed, and lashed to.
Old Sep 17, 2020 | 10:18 PM
  #33
AmmoVet's Avatar
AmmoVet
This is what I Use, works great for me.
Old Sep 18, 2020 | 07:44 AM
  #34
ShadowB's Avatar
ShadowB
Originally Posted by onthebottom
Brick Top: You're always gonna have problems lifting a body in one piece. Apparently the best thing to do is cut up a corpse into six pieces and pile it all together.
Just saying......
Old Sep 18, 2020 | 12:51 PM
  #35
RoadVettes's Avatar
RoadVettes
That's what I use also. Got it on Amazon for less then $15. Works great!
Old Sep 18, 2020 | 01:00 PM
  #36
iclick's Avatar
iclick
Same here, purchased on Ebay five years ago for $14. Works great.
