Default setting???
Old Oct 16, 2013 | 07:09 AM
bluedevil 1's Avatar
bluedevil 1
Default Default setting???
So.... here's the question. On the control for the settings, W-E-T-S-Tr , is there a default setting that it goes back to when the car is turned off? Mine goes back to touring when it is turned off and just wondering if that is standard.
Old Oct 16, 2013 | 07:26 AM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
No. Mine does not do that. You need to see Talon90's video on how the info system works. Let me tell you the thing drove me nuts for at least two days going through all the menus etc. someone can give you a link to that vid. After two weeks I think I have about 80% of the options. Still a long way to go with the radio and GPS...whew
Old Oct 16, 2013 | 07:33 AM
bluedevil 1
Can you tell me where Talon90's video is located? I think I have the system figured out quite well but was just inquiring about this oddity.
Old Oct 16, 2013 | 07:59 AM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
See if this works. If not then go to search at the top of the forum and enter infotainment video....
Old Oct 16, 2013 | 08:29 AM
Hot Rod Todd's Avatar
Hot Rod Todd
I found that if you shut it off in Track mode, it will default back to Tour, but if you shut it off in Sport mode it will be in Sport mode when you turn on the car. I never shut it off in Weather or Eco mode to see if it defaults back to Tour. I don't believe there is a menu setting that changes the default for drive modes, it is what it is.
Old Oct 16, 2013 | 08:40 AM
sammyv's Avatar
sammyv
Its a sticky at the top of the page.
To Default setting???
