Honk 3 times
Old Oct 17, 2013 | 10:51 PM
vetehead's Avatar
vetehead
Default Honk 3 times
Does anyone know how to stop the the car from honking the horn if you leave it running and walk away from car with fob in your pocket??Other then leaving remote in cup holder when exiting!
Old Oct 17, 2013 | 11:01 PM
runutzzzzz's Avatar
runutzzzzz
Under settings in the menu:
Remote Left in Vehicle Alert
This feature sounds an alert when
the RKE transmitter is left in the
vehicle.
Select Off or On.
Old Oct 17, 2013 | 11:13 PM
vetehead's Avatar
vetehead
vehicle.
Select Off or On.
Thanks, but not what I'm talking about here this is not leaving it in car but taking it with you when car is running and you exit.
Old Oct 17, 2013 | 11:47 PM
Cruiter's Avatar
Cruiter
On order: Torch Red Z51
It's in the settings. Mine didn't and I set it for the audible beep. That way I don't have to look back watching the lights flash. . But I do anyway, just can't help myself
Old Oct 18, 2013 | 01:31 AM
CaryKen's Avatar
CaryKen
Thanks a bunch for this thread title. Now I have Tony Orlando and Dawn running through my head on an endless loop.
Old Oct 18, 2013 | 02:12 AM
Stingray Sam's Avatar
Stingray Sam
It sounds like you have it set to automatically lock. You can change that setting, also.
Old Oct 18, 2013 | 05:48 AM
vetehead's Avatar
vetehead
Lol... :=)
Old Oct 18, 2013 | 10:22 AM
frikshun79's Avatar
frikshun79
I have the same issue. I have my "remote left in vehicle alert" set to Off, but when I get out of the car with it running and the fob in my pocket, and close the door, it still honks 3 times. But if I leave the fob in the cup holder, it wont honk. Seems backwards to me.
Old Oct 18, 2013 | 10:42 AM
gr814u2c's Avatar
gr814u2c
If you think about it, it is working how it is supposed to. Your key should be in the car while it is running, and outside of the car when the car is off. The car will do the 3 horn alert when either of the following happens:
Your car is running and the key ISNT inside.
Your car is NOT running and the key is left inside.
It honks to prevent the following scenario from happening:
You have the keys in your pocket, but somebody else is driving the car. You get in the car together, drive somewhere, you get out with the keys still in your pocket, and now the driver can drive away without a key. If there was no "alarm" from this, the driver of the car would end up at their destination, turn the car off, and have no way to turn it back on.
To Honk 3 times
