Oil Change question
Old Oct 20, 2013 | 02:09 PM
luvlake's Avatar
luvlake
Default Oil Change question
I have a Z51 with around 600 miles. I plan to lay her up for the winter in a week. Should I take to a dealer or have my usual mechanic change it. What oil filter should I use, manual says PF 64' in the past I have used Mobil one filters with Mobil 1 oil.
Old Oct 20, 2013 | 02:18 PM
BIg Wash AZ's Avatar
BIg Wash AZ
Default fire suit on
Any competent DIY, SAE mechanic, or oil change center can do the oil. Use a full synthetic from a reputable mfg, any name brand filter, and you are done. We have a C6 with 65K and with one exception, the oil has been changed at our neighborhood Jiffy Lube. They use Mobil 1 Synthetic 5-30 which is the OEM fluid and Fram filters. We pay attention to the DIC oil life monitor and follow its lead. The car is not a church to us so we don't obsess over the oil.
Old Oct 20, 2013 | 02:25 PM
Chrjones2's Avatar
Chrjones2
if you have someone other than a dealer change your oil, make sure you save all documentation and proof that it was done
Old Oct 20, 2013 | 04:12 PM
Larry/car's Avatar
Larry/car
How can you put the car away? There should be lots of dry winter drives in the future. I don't suggest just going out in the slop, discrete operation should enhance ownership. I use mine all winter, got to watch the tire grip verses temperature though.
Old Oct 20, 2013 | 04:38 PM
tbasco 6's Avatar
tbasco 6
The dealer will change it 4 times during the first two years under warranty.
To Oil Change question
