NPP Issue
Old Oct 23, 2013 | 05:08 PM
Litumup411's Avatar
Litumup411
Default NPP Issue
When I ordered the optional exhaust, I expected a mild to wild option menu.
There's not much difference at all when I change from mode to mode.
I ordered the 2LT M7 without the Z 51 package.
I have gone through the infotainment menu and switched the exhaust driving mode to "off", and this did not make a difference.
Hardly noticeable when it goes from eco-to sport.
Has anyone else had this issue?
Old Oct 23, 2013 | 05:19 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Yours may be not working. I have a Z-51 with the NPP and there is a major difference between touring and sport/track modes.
Mine barks, backs off and sounds nasty when open. I would make sure your electric NPP exhaust is working.
Old Oct 23, 2013 | 05:32 PM
ldepalma's Avatar
ldepalma
You can tell if there working just by looking at the baffles in the rear. The two outer ones should open when in sport/track. The difference is definitely noticeable.
Old Oct 23, 2013 | 06:37 PM
DocHolliday's Avatar
DocHolliday
You should definitely notice a different sound.
Old Oct 23, 2013 | 06:55 PM
Rad22's Avatar
Rad22
Check the fuse.
Homer3D's Avatar
Homer3D
With the car on, be in sport/track mode and look at the exhaust tips. Is the baffle open or closed?
Here is a video of someone switching between the modes. You can tell the difference.
Old Oct 23, 2013 | 07:07 PM
musclecar6's Avatar
musclecar6
You sure it came with the NPP ?
Old Oct 23, 2013 | 07:12 PM
HollywoodC7's Avatar
HollywoodC7
Would have been exceptionally nice and well received if that Damn Cam in the back ground wasnt getting us excited.....crap
Old Oct 23, 2013 | 07:17 PM
texvette2's Avatar
texvette2
can you guys us the stick or pencil method to keep the butterfly from closing.
On a BMW a BB would work in the vac line
Old Oct 23, 2013 | 08:25 PM
-CM-'s Avatar
-CM-
the difference is dramatic.
Old Oct 23, 2013 | 08:50 PM
Litumup411's Avatar
Litumup411
There's a slight difference. I guess I just thought it would be more dramatic. Definitely has NPP. I pulled both the left and right fuse, and that didn't make it louder either. I remember when I pulled the fuse on the Hertz rental Corvette convertible in 2010 and that was pretty raucous. Loved pulling up behind a slower car and dropping down 2 gears. The sound alone would have them scurrying out of the way!
Moral...Don't buy a rental!
To NPP Issue
