Prepare for starter failure
People should be more respectful when someone reports they have an issue. Maybe the OP didn't handle his post in the optimal manner, but there was no reason to 'call BS' or suggest he is making stuff up. It happens too often on the forums. People seem over sensitive about others reporting problems. Thanks though.
Exactly. Don't have a C7 but have had this happen to me in my track C6 due to a faulty rear-mount battery install. The only good thing was that it happened in a grass parking lot and we were not in the car (indian wells open), but I can confirm that this is a nightmare. The car is 100% dead - can't open doors, can't tow, can't get to anything to revive it. The tow guy could not even get a slim jim into the door. Oh, and the spare key for the trunk you ask? Lock cylinder broke off as we tried to open it. Cost me $1,500 by the time we were done, and luckily it was a short tow when we figured out how to get it on the truck, 7 hours later. I would hate to have this happen on a road trip far from home.And to the doubters - the joke is on you. This is a mass-production car. If this happened once, it will happen again. It is probably a faulty electronic part. As the OP says, listen or don't, but you have been advised.
I've replaced one starter in my lifetime, that back in the early 70s. And I can't remember any of my friends ever replacing a starter.
- It started with a supplier problem, a fuel tank sending unit that failed just prior to delivery.
- The selling dealer in KS diagnosed and replaced the defective part, which required dropping the driveline and fuel tanks.
- it's likely that during reassembly a plastic coated wire got misrouted and/or pinched under a metal part. With heat and a few hundred miles the plastic coating of the wire was penetrated, allowing the core of the wire to short out to metal.
- The short circuit blew a fusible link or a fuse and the car went dead.
- The driver shifted to park to restart the car but it was dead.
- Now the car wouldn't come out of park because of no power to the park interlock
- Neither the owner nor the tow truck driver nor the policemen knew how to manually release the new model's automatic shifter from Park when there is an electrical failure so they had to use dollies to move the car. (On more common cars most tow truck operators know how to get to the park-lock release when a car is dead).
Fusible links have protected cars' major circuits for many years, keeping cars fom going up in smoke. Many modern GM cars have gone to big Maxi-fuses instead. If the C7 was still protected by fusible links the starter would indeed have to be removed to get to the fusible links above it.
Hopefully the OP will have his car back within days and will update us with the final story
If this is real and the OP just doesn't understand what happened, I am sorry for them.
On the other hand the facts are sketchy and don't add up as reported.
Sounds sort of like: Do you want to see that pot of gold I have hidden in my cave?
