Gas Funnel
Old Nov 4, 2013 | 06:08 PM
bertes1's Avatar
bertes1
Default Gas Funnel
Has anyone found the gas funnel mentioned in owners manual. I haven't located it. should I contact agency ?
Old Nov 4, 2013 | 06:12 PM
peetoom's Avatar
peetoom
Check page 9-54 of the manual
Old Nov 4, 2013 | 06:18 PM
elegant's Avatar
elegant
Have you checked the center console and the "below cargo floor" drivers-side cubby (places other folks have found theirs)?
Old Nov 4, 2013 | 06:20 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It should be in the plastic bag that also contains your owners manual. It is fairly small at about 1.5" diameter and about 8 inches or so long.
Old Nov 4, 2013 | 06:30 PM
Newstingray's Avatar
Newstingray
Mine was in the trunk in a plastic bag.
Old Nov 4, 2013 | 06:43 PM
green2000's Avatar
green2000
Mine was in the trunk storage compartment loose with no bag.
Old Nov 4, 2013 | 07:18 PM
-CM-'s Avatar
-CM-
There is a slot on the battery cover designed to hold it. Pull up the carpet in the right rear corner of the cargo area.
Old Nov 4, 2013 | 08:24 PM
bertes1's Avatar
bertes1
As I see it I have to remove the right rear wheel cover, raise the carpet and see if there is a funnel there. Not what I expected when i bought the car.
Old Nov 4, 2013 | 08:26 PM
-CM-'s Avatar
-CM-
No, just pull up the carpet from the corner.
Old Nov 4, 2013 | 08:31 PM
Glen e's Avatar
Glen e
....it is usually put in the cubby storage on the driver side rear area by the PDI people...
Old Nov 4, 2013 | 09:05 PM
-CM-'s Avatar
-CM-
Here's what mine looks like. The indentation in the battery cover is actually formed to hold the towing bolt for EU cars, but the funnel fits in one end nicely.
To Gas Funnel
