Design Element or Patch?
Old Nov 5, 2013 | 04:15 PM
MRREDDOG's Avatar
MRREDDOG
and not so much in this area, but the other side, at the wheel well probably looks worse, that's where it will show more....
Old Nov 5, 2013 | 04:19 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by KenHorse
Quite honestly, I attended several presentations by one of the "insiders" on the C7 and one highlighted feature was how a much stiffer frame and new composite materials used in the body panels allowed for much closer inter-panel spacing and tighter tolerances (as I remember, the figure was 3 mm as opposed to the previous 7 or 8).
I'm not ragging about this but I would expect superior fitment than that pic shows, based solely on GM provided information.
Just sayin'......
3 mm is ~.118" or nearly an 1/8". I guarantee that photo (magnified as it is) shows an actual panel gap of 2 to 2.5 mm when viewed at scale by an eye.
Just sayin'.........
Old Nov 5, 2013 | 04:22 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
You may not see a reason for them, but others do. I mean, other car manufacturers since it goes back at least ten+ years of being on different cars. I saw them on a 2003 Infiniti. I'd bet others had them, from the factory, on older cars.
Old Nov 5, 2013 | 04:24 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
The gap width itself isn't the issue that I see. The offset of the upper panel to the lower one is the issue I'm referring to
Old Nov 5, 2013 | 04:33 PM
talon90's Avatar
talon90
NCM Ambassador
Originally Posted by sam90lx
It's called Blinders!
No actually it isn't. It's called having a very thorough knowledge of composite materials and the SMC molding process. It's called understanding of tolerance stack up and design for manufacture and assembly.
Old Nov 5, 2013 | 04:38 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Originally Posted by jagamajajaran
The orange peel stuck out to me in those pics.
It wouldn't be a Corvette with out OP. You ought to see the area on mine, in the cove, that's part of the rear fenders, where you open the doors.....
Old Nov 5, 2013 | 05:09 PM
gthal's Avatar
gthal
I agree... no blinders here. I have seen some panel gaps in C7s posted here but in the picture above, that variance is so small that it isn't a fitment issue IMO. I would bet you could find such a small tolerance difference on most any car somewhere if you looked hard enough for it. But, hey, it's much more interesting to find a problem than to not two
Old Nov 5, 2013 | 05:19 PM
KenHorse's Avatar
KenHorse
Actually, I would argue that since GM's target audience isn't folks well versed in composites and manufacturing tolerances, that's a pretty weak argument to make
Old Nov 5, 2013 | 05:24 PM
Slappy3243's Avatar
Slappy3243
The C7 will never do right by some people and it never will. That's just the way it goes. Back when I lived in Virginia I became good friends with a guy who owned a body shop which catered to high end cars. I would take my GTO there because I knew how much care they put into their work. Anyway, he told me how frustrating it can be to work on handmade cars like Ferrari because it was next to impossible to get the panels to line up correctly and how the panel gap was completely inconsistent from one car to the next. I would rather deal with the C7's issues than what I described above on the exotic cars. Somehow, it's acceptable on them since they are hand crafted and no human is perfect.
Old Nov 5, 2013 | 05:26 PM
gthal's Avatar
gthal
That wasn't my point. I was suggesting the issue is so nominal on this particular car that unless you were TRYING to find something wrong when standing next to the car you wouldn't notice it. I would also bet you could find such nominal variances on most any car if you looked hard enough. I'm not suggesting that some cars didn't have a couple of panel fitment issues... they did... I'm suggesting some people are now trying to find problems so they can say they found a problem.
Old Nov 5, 2013 | 05:29 PM
KenHorse's Avatar
KenHorse
Fair enough
(I'm really not this **** but some things are too obvious to me as to be ignored)
Old Nov 5, 2013 | 05:37 PM
texvette2's Avatar
texvette2
see what they mean now about the poor paint quality on red
Old Nov 5, 2013 | 05:39 PM
  #33
gthal's Avatar
gthal
Agreed... very noticeable. But, as I've said before, this is NOT a GM specific issue. My M3 looked the same (it was black). That's not an excuse because they should be better but it's not just on the C7.
Old Nov 5, 2013 | 06:04 PM
  #34
335i's Avatar
335i
Originally Posted by Bisha
Is this on all C7's and if so, what is it and why? I just noticed these "patches" (don't know what else to call them) on both sides of my car. They are behind each door and go down to the rocker panels and then forward about half the door length and are "glued" to the car. I do not see a reason for them and it seems that it is asking for future problems to expose seams of any sort to the road and weather elements that they will face over time.
Is this Torch Red or Crystal Red?
Old Nov 5, 2013 | 06:14 PM
  #35
OnPoint's Avatar
OnPoint
The Consigliere
I sure hope the paint finish improves on these cars going forward.
Old Nov 5, 2013 | 06:16 PM
  #36
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
Hate to say it, but Im gonna. Go look at a $30,000 Honda. or better yet a lexus. That's how you do panel gaps. They all should be even. And yes the Honda has better paint work.
GM, Come' on Man...................
Old Nov 5, 2013 | 06:20 PM
  #37
BlueOx's Avatar
BlueOx
Well, we just aren't subjected to macro photography of the Honda's panel gaps now are we? I guess if you want to stare at Honda's, go for it. Took me all of 10 seconds to find this Honda complaint thread and pics...
Interior gaps...
Orange peel...
Runs along the bottom...
http://www.driveaccord.net/forums/sh....php?p=1051791
Old Nov 5, 2013 | 06:22 PM
  #38
OnPoint's Avatar
OnPoint
The Consigliere
How about their paint finish?
