Alignment after lowering?
Old Nov 5, 2013 | 10:48 PM
Motohead279's Avatar
Motohead279
Default Alignment after lowering?
For those who have lowered their cars with the leaf spring tension bolts, did you need to get your steering aligned? I remember hearing that it might need to be done afterwards.
Old Nov 5, 2013 | 10:51 PM
Glen e's Avatar
Glen e
No you do not for daily driving for this mild a lowering. Two good shops in s fla did not align theirs and neither did I.....
BuT stay tuned, many will argue here.....I'm out....
Old Nov 5, 2013 | 10:52 PM
sajonf's Avatar
sajonf
Agreed no need.
Old Nov 5, 2013 | 11:12 PM
Motohead279
Glen... Lol
Old Nov 5, 2013 | 11:21 PM
ChucksZ06's Avatar
ChucksZ06
If you want it correct you need to check it.
Old Nov 6, 2013 | 12:10 AM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Glen, I gotta argue with that statement...no one argues with anything on this forum. Stop being such an old geezer!
As for the alignment...I'm going to go with what Glen said.
Old Nov 6, 2013 | 10:30 AM
ZZR1200's Avatar
ZZR1200
You are right on Glen. Show a black car and people will jump on you to argue it is white.
Old Nov 6, 2013 | 10:48 AM
stevebz06's Avatar
stevebz06
Not having a C7, I don't know for sure, but having done it on a C5 and C6 and then having measured it, they both needed toe in added at the rear, the front had a negligible change. But if you want a really exciting ride, drive your C7 with the rear toed out.
Old Nov 6, 2013 | 11:04 AM
c6rod's Avatar
c6rod
From prior experience with lowering and quality of factory alignment, I would check the alignment after lowering. It is $100 of assurance that improper alignment will not cause premature tire wear and insure drivability.
Old Nov 6, 2013 | 01:44 PM
KayJay's Avatar
KayJay
Agree with c6rod...what's a few bucks for peace of mind, not to mention a possible need for realignment not even related to lowering?
Old Nov 6, 2013 | 04:30 PM
Turbooo2u's Avatar
Turbooo2u
Is the lowering METHOD the same as before? "Loosen" to lower?
Old Nov 6, 2013 | 06:29 PM
louloumax's Avatar
louloumax
lower it and just drive it. check tire wear in 1000 miles. if they are uneven, then align it and yell at me and others.
Old Nov 6, 2013 | 09:02 PM
Tannman's Avatar
Tannman
Always realign when lowering. I have done it on my C5 and C6. If I lower my C7, I will realign.
Old Nov 6, 2013 | 11:41 PM
1986C4Z51's Avatar
1986C4Z51
Actually, just before you sign the contract, pause, look up and say, "3 out of 4 cars I have bought from GM needed an alignment out of the showroom, and I'm tired of this and I want an alignment done with a printout provided to me of before and after, before I take delivery of this car."
My first Vette was so bad I couldn't look away from the road for a second without almost ending up in a ditch.
Old Nov 6, 2013 | 11:46 PM
Motohead279
I'll get it checked out when I do it was just curious if anyone actually needed an alignment after. If it doesn't then great, if it does then well it does.
Old Nov 6, 2013 | 11:55 PM
ZL-1's Avatar
ZL-1
Some people say you need an alignment after lowering, some say you don't. The answer is Maybe.
If you turn the height adjusters while the car is on an alignment rack you can watch the camber and toe change with each turn. BUT if you were well within the spec range to begin with you still might not be out.
The alignment at Bowling Green isn't terribly precise to begin with. The cars are so high coming of the line, the BG alignment has to compensate for a bit of settling that will occur.
It's not a bad idea to get a few thousand miles on the car, get the ride height just where you want it, and then get it aligned right on spec, not just within the + or - range. The expense of a good alignment might pay off in a bit more miles out of the Michlins
Old Nov 6, 2013 | 11:58 PM
1986C4Z51's Avatar
1986C4Z51
YES! The back end ended up toed out. This is very unstable and will possibly lead to being dead from spinning out. I'm not talking about a little extra tire wear. I'm talking about a potentially dangerous situation. Anybody who tells you otherwise probably didn't actually check.
It might be possible that the geometry on the 7 has changed to where I am wrong on this, but the 5 and 6 were this way, so until it's been established otherwise, get an alignment and let us know.
To Alignment after lowering?
