Tire temp not working.
Old Nov 22, 2013 | 07:59 PM
00hotvette's Avatar
00hotvette
Default Tire temp not working.
Ok it's say WARM tire temp but there is no way as I never moved the car. Anyone else seeing this?
Old Nov 22, 2013 | 08:00 PM
shaan's Avatar
shaan
I believe that it only shows it on the touring mode, mine is the same
Old Nov 22, 2013 | 08:06 PM
00hotvette's Avatar
00hotvette
Mine is in sport mode and the tires are cold. Should this go (Cold) (Warm) (hot). It's always say warm!!
Old Nov 22, 2013 | 08:18 PM
Bill B 1's Avatar
Bill B 1
It should do just that....mine is always on warm. Even on a 30 degree morning when I checked it just for courosity the other day.
Old Nov 22, 2013 | 08:50 PM
Sidepiper's Avatar
Sidepiper
Mine too....but it is garage kept. My garage is not heated. I want to see cold tires so I can be scared until it turns to warm...then I'll drop the hammer.
Old Nov 22, 2013 | 08:53 PM
RickConti@Coughlin's Avatar
RickConti@Coughlin
you get the cold, warm or red readings while in the "PERFORMANCE" tab ( left click your arrow on sterring wheel ) The go up to INFO and then in the "INFO" tab, use up and down arrows and you'lll get actual presssure readings
and it does read cold...again in the PERFORMANCE TAB
Old Nov 22, 2013 | 09:16 PM
NeedAVetteForVIR's Avatar
NeedAVetteForVIR
Hmmm...I was wondering if mine was broken too. I don't think I have ever gotten the tires hot yet, but the other day I parked it outside for 75 minutes in 37 degree weather and it still said warm...Suspect
Old Nov 22, 2013 | 09:26 PM
RickConti@Coughlin
hope this helps
Old Nov 22, 2013 | 09:41 PM
NeedAVetteForVIR
Originally Posted by RickConti@Coughlin
hope this helps
Thanks for the info: Just to be clear, I am not having problems seeing the tire temp display or switching to the tire pressure display, but the temps have never changed from "warm" in temps ranging from a 37 degree cold start to spirited driving in 74 degree weather today. It's suppose to get really cold Sunday and I'm going to park the car outside for a few hours to see what happens.
Old Nov 22, 2013 | 10:43 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
Mine finally read cold, C7 was parked outside in 25 degree weather for 12 hrs. I drove for 5 miles at 60mph and then they read warm. I have never seen hot.
Old Nov 22, 2013 | 10:45 PM
00hotvette's Avatar
00hotvette
Ok did what you said and got this.
Old Nov 22, 2013 | 10:46 PM
00hotvette's Avatar
00hotvette
Then this.
To Tire temp not working.
