C7 Future: Technical
Old Dec 4, 2013 | 02:08 PM
Runge_Kutta's Avatar
Runge_Kutta
Brembo Brake Patents
8349231 Shaped composite material
7700181 Shaped composite material for breaking applications and a method for the preparation thereof
7172723 Method of producing a shaped composite material
6802403 Disk-brake disk
Here's a video on what apprears to be Brembo carbon composite rotors:
Magnesium door panels
http://www1.eere.energy.gov/manufact...ng_process.pdf
Magnesium inner panel in Cadillac SLS
http://www.intlmag.org/showcase/Fall2013_Issue21.pdf (page 2)
GM wins DOE funding for "Development of Energy Efficient Integrated Die Casting Process for Large Thin-Walled Magnesium Applications"
http://www5.eere.energy.gov/projects...lled-magnesium
Magnesium production
http://wardsauto.com/vehicles-amp-te...weighting-uses
Aluminum metal-matrix composite brake drum video
Old Dec 4, 2013 | 02:56 PM
ChucksZ06's Avatar
ChucksZ06
You guys can make fun of skullbusa all you want but he is correct about the only way to significantly improve mpg is with lighter vehicles. I do not want to go back in time in any way but mpg has not significantly improved for 3 to 4 thousand lb vehicles since the late 50's. You could get 18 to 20 mpg highway with stock 1957 gm vehicles. I also agree the manufacturers are doing a great job complying with laws and providing wonderful cars. My son recently did a tour in Afghanistan and was telling about new brand name cars that sell for 2,000.00 there. They are totally stripped versions. Those vehicles would sell here if they were legal. Please save the safety and environment remarks as I am just trying to make a point.
Old Dec 4, 2013 | 05:54 PM
Runge_Kutta
Personalized Brake Rotors (scroll down to the 3rd page):
http://www.freepatentsonline.com/20130133995.pdf
Old Dec 4, 2013 | 06:49 PM
eshuber's Avatar
eshuber
Thanks for the great post.
Old Dec 4, 2013 | 09:18 PM
HellPhish89's Avatar
HellPhish89
concerning composites.. GM, Ford, Mercedes, and a couple others were supposedly working on a project to create a mass producible carbon composite. dont know what came of it but yea. also, the carbon brakes on teh ZR1 are actually 1/3 of the price of what that sort of package used to cost.
Old Dec 5, 2013 | 02:16 PM
Runge_Kutta
Magnetorheological fluids - They seem to be adding some non-magnetic particles in with the magnetic particles. Two stated goals are reduced sized and mass.
http://www.freepatentsonline.com/7354528.pdf
http://www.freepatentsonline.com/7419616.pdf
http://www.freepatentsonline.com/7900755.pdf
http://www.freepatentsonline.com/8361341.pdf
http://www.freepatentsonline.com/7393463.pdf
http://www.freepatentsonline.com/7521002.pdf
http://www.freepatentsonline.com/8226845.pdf
http://www.freepatentsonline.com/8470193.pdf
Wheels - These are aluminum wheels with a magnesium insert.
http://www.freepatentsonline.com/20120086264.pdf
http://www.freepatentsonline.com/20120088116.pdf
Traction Control
http://www.freepatentsonline.com/20070061061.pdf
Hydroforming - The 2005 application seems to have died. Too bad, it looked cool. These papers probably tell you a lot about how the C6 and C7 aluminum
frames are built.
http://www.freepatentsonline.com/6732434.pdf
http://www.freepatentsonline.com/6922882.pdf
http://www.freepatentsonline.com/7386938.pdf
http://www.freepatentsonline.com/7774925.pdf
http://www.freepatentsonline.com/7143618.pdf
http://www.freepatentsonline.com/7543384.pdf
http://www.freepatentsonline.com/7941907.pdf
http://www.freepatentsonline.com/20050279049.pdf
Automatic Transmissions
- There are so many (well over 100) GM patents on eight-, nine-, ten-, eleven- and twelve-speed transmissions, I'm not even going to try and be
comprehensive.
12-Speed:
http://www.freepatentsonline.com/8409045.pdf
11-Speed:
http://www.freepatentsonline.com/8403802.pdf
http://www.freepatentsonline.com/8435154.pdf
http://www.freepatentsonline.com/8512197.pdf
Old Dec 6, 2013 | 04:04 AM
RPOZ51's Avatar
RPOZ51
From: For the strength of the pack is the wolf . . . . . . and the strength of the wolf is the pack.
Originally Posted by fdxpilot
OP, try using carriage return once and awhile. When my IPad auto-sizes the chrome window, due to your very long lines, the print size is so small I need a magnifying glass.
I don't think that's what is doing it. Text will automatically wrap.
I think it's the way the YouTubes were imbedded. Need to use the [yt] tags.
EDIT:
Actually, it was probably the very long string at the end of Post No 11.
