VIN sequence?
Old Dec 4, 2013 | 08:32 AM
No Shot's Avatar
No Shot
Default VIN sequence?
how do I tell what # in the VIN sequence my car is? the last 4 of my VIN is 4720. does that mean it was the 4,720th off the line?
Old Dec 4, 2013 | 09:12 AM
Rich427's Avatar
Rich427
You are correct that 4720 is your VIN sequence but that does not mean it was the 4,720th car off the line. I believe each vehicle is assigned a manufacturing sequence number and that determines how they come down the line. But I don't think the VINs are too far out of sink with the sequence number. I hope this helps.
Old Dec 4, 2013 | 10:11 AM
JoesC5's Avatar
JoesC5
No, as GM produces several models with different VIN's. Your car is #4270 meaning that your car is #4720 of that model. A premiere edition has it's own unique VIN and they also start at 00001 and the captured test cars have their own unique VIN that also starts out at 00001. The complete VIN is different as there are other characters in the VIN that are different other then the last five. Therefore, even though they may be three different C7s with identical last five characters, they do not share the same VIN.
If they built, say, 300 captured test cars and 500 premiere editions cars before you car was built, then it is likely that your car was the 5070th C7 built when your car rolled off the line.
Old Dec 4, 2013 | 11:40 AM
No Shot's Avatar
No Shot
so it's fairly safe to assume mine was # 4720 of the "stock" C7's as they began to roll out into circulation?
Old Dec 4, 2013 | 12:06 PM
BPhillyc8's Avatar
BPhillyc8
Yes that is correct. I am 4709! We were on the line at the same time. Ha.
Old Dec 4, 2013 | 12:59 PM
JoesC5's Avatar
JoesC5
I you want to know how many C7's were built before yours, take the inked stamped number on the tires and subtract one from it.
To VIN sequence?
